Old 01-11-2013, 06:17 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Default Where to tap into for wires? hi/low convertor
Hey guys im adding subs to my stock stereo, where are all the wires located in the truck that i need to tap into? Wheres the easiest place to tap in at?
Thanks guys
Old 01-12-2013, 04:07 PM
Jon3sgte Jon3sgte is offline
Vehicle: 2012 Ram CC
Trim Level: Tradesman
Rep:30
Jon3sgte is on a distinguished road
From what I've been told: tap into the rear speakers right at the door pillars. (right behind the front seats) I unfortunately can't help you out with wire colors.
Old 01-14-2013, 12:04 AM
Ryank's Avatar
Rep:199
thanks if anyone else has done this what are the wire colors?
Old 01-14-2013, 03:36 PM
Rep:30
I figured mine out this weekend. Dark green/light green stripe is your positive and Dark green/white stripe is the negative. (pass side) Take off the lower pillar cover (it pulls right off) and pull the plug from the door. I tapped in to that plug. the two wires are side by side. Hope this helps.
Old 01-15-2013, 11:20 AM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
Honestly. If the money was there. New aftermarket stereos are always nice, and subs its basically just plug and play for them
Air horn "AHHOOOGA" horn,
Green Interior LEDs
Old 01-15-2013, 12:03 PM
Ryank's Avatar
Rep:199
Ya I know but I don't really want a aftermarket radio right know.
Old 01-15-2013, 02:26 PM
Rep:30
I'd like a new receiver as well but they dont look good in the dash. It looks much cleaner OEM than with a "kit" to make the new deck fit the opening.
