Old 01-11-2013, 06:42 PM
hoboverlord hoboverlord is offline
Vehicle: 1996 Dodge RAM 1500 Laramie
Color: Red & Black
hoboverlord is on a distinguished road
Thumbs down I got these awesome codes today from the mechanic. What should I do tho fix all of this?
codes are for a 1996 Dodge Ram 1500 Laramie, 2WD, 5.9L. V8.
Here we go...
P0138
P0340
P0132
P0783
P1763 x2
P1762
P0135
P0141
P0300
P0302
P0740
I don't even know where to start with this. Any help would be appreciated.
Old 01-11-2013, 07:30 PM
Rep:2705
all of your codes are for the PowerTrain, therefore the P
Here is the list of codes
http://www.edgeproducts.com/product_...cle-pdf-39.pdf
P0132 1/1 O2S Shorted To Voltage
P0135 1/1 O2S Heater Failure
P0138 1/2 O2S Shorted To Voltage
P0141 1/2 02 Sens Relay
P0300 Multiple Cylinder Misfire
P0302 Cylinder #2 Misfire
P0340 No Cam Signal At PCM
P0740 Torque Conv Clutch, No RPM Drop at Lockup
P0783 3-4 Shift Sol, No RPM Drop at Lockup
P1762 Gov Press Sens Offset Volts Too Low or Hi
P1763 Governor Press Sens Volts Too Hi
Good Luck
Old 01-11-2013, 07:39 PM
Color: Red & Black
So with the codes I have, what would be a good place to start with fixing these? (Besides, of course, driving it off a cliff. This is not an option
I should also the performance issues I am having. The truck seems to run fine until I come to a stoplight or stop sign. When I press the gas to resume driving, the vehicle tries to die. (I should also note, it has died once since I have driven it. The truck lurched forward after I restarted it and resumed "normal operation".)
Old 01-12-2013, 01:00 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
This is what I came up with:
A code P0132 may mean that one or more of the following has happened:
•The oxygen sensor heater circuit is shorted out
•The wiring to the sensor is broken / frayed (less likely)
A code P0135 may mean that one or more of the following has happened:
•O2 Heater element resistance is high
•Internal short or open in the heater element
•O2 heater circuit wiring high resistance
•open or short to ground in the wiring harness
A code P0138 may mean that one or more of the following has happened:
•Faulty O2 sensor
•Short to battery voltage in O2 sensor signal circuit
•High fuel pressure (not as likely)
A code P0141 may mean that one or more of the following has happened:
•O2 heater element resistance is high
A code P0300 may mean that one or more of the following has happened:
•Faulty spark plugs or wires
•Faulty coil (pack)
•Faulty oxygen sensor(s)
•Faulty fuel injector(s)
•Burned exhaust valve
•Faulty catalytic converter(s)
•Stuck/blocked EGR valve / passages
•Faulty camshaft position sensor
•Defective computer
A code P0302 may mean that one or more of the following has happened:
•Faulty spark plug or wire
•Faulty coil (pack)
•Running out of fuel
•Poor compression
•Defective computer
A code P0340 could mean one or more of the following has happened:
• a wire or connector in the circuit could be grounded/shorted/broken
•the camshaft position sensor may have failed
•the PCM may have failed
•there exists an open circuit
•the crankshaft position sensor may have failed
P0740 Torque Converter Clutch Circuit Malfunction
P0783 3-4 Shift Malfunction
P1762 Shift Lock Short to B+
P1763 Shift Lock Open
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 01-12-2013, 04:19 PM
Color: Red & Black
Thank you Sabin and GT. So with all of these issues, where should I start trying to fix this vehicle?
Old 01-12-2013, 05:28 PM
TinMan68 TinMan68 is offline
Vehicle: 2013 Dodge Ram 1500 Express
Trim Level: Express Quad Cab
Rep:48
TinMan68 is on a distinguished road
Here's some food for thought. 1996 was the first year that OBD2 codes were mandatory, and some of the computer systems in 1995-1997 OBD2 cars were a bit idiosyncratic. You may want to erase them all and see what comes back after a few starts and start from there! In other words some of these codes might not even be valid!
2013 Dodge Ram 1500 Express Quad Cab 5.7L Hemi With 6 Speed Automatic And 3:55 LSD Gears and 20 Inch Rubber
2002 A6 3.0L 30V Quattro Avant Auto
2003 Nissan 350Z Enthusiast Model 6 Speed Manual
Old 01-13-2013, 02:09 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I concur with the tinman, if you haven't bought an obdII reader/eraser yet, start with ebay... But for now, turn your key to ignition without the engine running, disconnect the neg battery cable, turn the ignition key off, reconnect the neg cable, and go thru a drive cycle, and re read the codes. I suspect you have less issues than your current codes indicate, at least I hope so. Start by opening your throttle up and looking down the engine intake with a flashlight, if theres oil on the bottom, a good place to start would be pulling the intake and replacing the gasket on the bottom of the intake if theres oily residue down there. That may well be the misfire deal. I have never seen the cam signal missing thing, I suspect that may disappear on a reboot of the ECU. As far as o2 sensor codes go, a good start would be to ensure the wires are connected to the sensors, or that the sensors aren't smashed. The sensor I have dealt with is the one on the passenger side, beneath the cab, on the exhaust pipe. I 'm guessing someone removed it with a shadetree exhaust system... hopefully you still have the wires and connectors on the truck, put one on, get the weldment for it from a muffler shop, and weld it on the pipe, after the converter, if I remember right, but point it sideways, so it doesn't get ripped off by sticks and tall grass, etc. If you get this far, post again...
