Old 01-11-2013, 10:42 PM
svhssoccer09's Avatar
svhssoccer09 svhssoccer09 is offline
Vehicle: 2007 Dodge Ram 1500
Color: Yellow
svhssoccer09 is on a distinguished road
Default Back seat removal
Hey guys trying to remove my backseat in my 07 to try and fix a leak in exchange vents. Does anyone have a diagram of how to remove seats? I am seeing a lot of people saying 4 & 6 bolts but I count 9 or so. Also size of bolts if anyone knows?
Old 01-13-2013, 03:02 PM
buzzvoodoo buzzvoodoo is offline
Vehicle: 2002 quad cab 4.7L
Trim Level: Quad cab
Color: yellow
Rep:13
buzzvoodoo is on a distinguished road
I have found that this site is very big with a lot of traffic but not many people take the time to post a reply or help. I have an 02 and just recently bought a ram 1 month ago so I will not be of any help but I have always found that just going at it blind sometimes is the best way. Just get your socket set and spanners and just start unbolting things and you will discover how it all goes together quickly. A little advice save the bolts in a good spot so you dont lose them. Sorry I cant be of more help but dodge designed these things fairly decent.
Old 01-20-2013, 09:06 PM
mrfblack08laramie's Avatar
mrfblack08laramie mrfblack08laramie is offline
Vehicle: 2008 Dodge Ram Laramie
mrfblack08laramie is on a distinguished road
The number of bolts depends on if you have a solid or split bench seat. I don't remember the size but I do think you also need to remove the seat belt bolts. They are a torx or star shaped bolt. When you take the seat out, lift up before you pull it out. There are hooks on the back of the seat that slide over "rings" that are attached to the cab wall.
Old 01-20-2013, 09:10 PM
One more thing, some of the bolts go thru the floor and are exposed under the cab. You may need to spray those underneath the cab if they don't want to come out easily.
Old 01-20-2013, 09:48 PM
ShawnC13's Avatar
Cheap Canadian Labour
Rep:1808
I have an 08 with a solid seat in the back not split. It was only 4 bolts as for the size I can't remember as I took it out a long time ago. I had a long breaker bar for a couple of them as they were tough to get out but after you get them started the rest comes easy. There is a way to have hte back seat flip down as well.
