What torque converter with rear 4.10 gears - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-14-2013, 07:49 AM
hodgeee's Avatar
hodgeee hodgeee is offline
Vehicle: 2012 dodge ram 1500 2x4
Trim Level: express
Rep:134
hodgeee will become famous soon enoughhodgeee will become famous soon enough
Default What torque converter with rear 4.10 gears
Ok guys, I know that the RT models are supposed to have a slightly more aggressive torque converter than the standard models, does anyone know how much more aggressive it is, would it be worth it? But first let me explain. I have to drive a bit in the mountain areas surrounding las vegas, and when I have done a torque converter before, it made the vehicle drive really poorly in the hills, or I could down shift and drive at 3000rpms, or more, constantly to keep the transmission from shifting back and forth. I had a 2800 stall before, and it would not drive the vehicle correctly up hills at anything below 3000rpm, it would slip, then down shift and then up shift then down, so on so on.
This was in a corvette. I loved the performance all around with the converter, just bad ass, but I don't want to give up my normal drivability in the mountains either. I am putting 4.10 gears in soon, and wanted to do a converter at the same time. I want improved performance, and know that a 2600 to 3000 stall would be great, but would mess up the drivability for what I am looking for. I know also that I will be giving up a huge increase, but I still want an improvement over stock.
Anyone know the stall speed of the stock RT unit, or about how much it would cost?
BellTech 2/4 Street Performer, Spohn PanhandRod, Hellwig Sways, Volant Intake(Donaldson Filter), 85MM Fastman Throttle body, 14" Magnaflow, T1000 w/Hemifever Tune, 180 T-stat, 4.10 Gear Swap, Edge Street Perf - 2600 Stall, Billet Catch Can, E-Fan Swap, ARH LongTubes
Old 01-14-2013, 09:21 AM
Rep:1388
RT stall is ~2600 rpm. Stock I think is like ~2000-2200 rpm.
I have a 2800rpm stall in my 4.7L and below half pedal it doesn't really act much different than stock if at all. And the stock converter for the 4.7L is more like ~2200-2400rpm IIRC.
Old 01-14-2013, 09:44 AM
hodgeee's Avatar
Trim Level: express
Rep:134
So the RT stall will give better performance and maintain most all drivability? With your 4.7 and 2800 stall have you driven many mountain grades?
Maybe since my last converter was on a Vette, it just slipped more than a truck. But either I went screaming up the mountain side in low gear or I let it just shift up and down continously. In town of course it drove like stock, until you stomped it!
Old 01-14-2013, 09:47 AM
Rep:1388
What gearing did the vette have? And what brand converter was it?
I live in FL so no not often in the hills, however I hauled ~1,000-1,500lb from FL to TN then TN to AR then AR to FL (2600 miles in 1 week) last July. The truck had to kick down from 6th to 5th on the steep grades(holding 75mph) but it did that stock too. I have 3.55's and am quad cab. It drove great through the mountains, I didn't feel like it was shifting too much or holding low gears or anything like that. My converter is a billet edge. Like I said even on moderate grades it wouldn't leave 6th gear, so with your hemi and 4.10's you should be fine. But it's all relative...
And IMO if you are buying a converter, go aftermarket. Edge and Circle D seem to be the most popular for the ram 1500s. You'll pay the same price for the RT converter but aftermarket is probably better.
Old 01-14-2013, 08:24 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Rep:20
gopackgo69 is on a distinguished road
Defiantly get after market, edge or circle d, 2600-2800 in my opinion. same say 2800-3000. Just talk to either of the guys at those 2 places, tell them your mods and expectations. But it's not rocket science, go with either 2 stalls I mention. I recommend the 2600-2800 though.
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 01-14-2013, 08:45 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
I had a Circle D 3k on my trailblazer SS and absolutely loved it. Great TC. No complaints. Could definitely tell a difference.
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 01-15-2013, 12:44 AM
hodgeee's Avatar
Trim Level: express
Rep:134
thanks guys for the info, will go aftermarket especially if the cost is the same, and the circle D converters are super tuff from what I have read
Old 01-15-2013, 10:29 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
the 4.10's will definitely help the gear hunt issue since your running 3.55's now. and a pretty safe stall in a regular cab is 2800-3000. If you talk to tq verter mfg they may push a higher stall but since you do mountains, it's like equating to towing and I would keep it lower to keep the temps down... I started with a 2600 in my qc and then had it bumped to 2800, now I wished I could have kept it at 2600.
Old 01-15-2013, 09:44 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Chefred what made you want the 2600 back?
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 01-16-2013, 04:20 AM
brentwood's Avatar
brentwood brentwood is offline
Vehicle: 2016 Ram 2500
Trim Level: Tradesman CC 4x4
Color: Black Pearl
Rep:49
brentwood is on a distinguished road
stock is 2300, rt converter is 2600
The rt converter is a good improvement over stock, if you can find a used one at a good deal.
I have a 2800 street edge and spin the tires easily in my quad cab.
Best bet would be a 2600 stall from edge or circle D.
