Old 01-12-2013, 10:12 AM
guesstimator guesstimator is offline
Vehicle: 2011 Ram Crew Cab
Rep:27
guesstimator is on a distinguished road
Default 3/8" spacers on factory wheels
As I posted in another thread, I just had some 35" Toyo MT's put on my factory wheels. It's a 2011 CC 4x4. There is some rubbin on the a-arms at full turn. A buddy gave me some 3/8" spacers to help with this. Do you think I would be ok running this on a factory wheel/studs setup?
And they don't quite measure 3/8", more like 1/2".
Old 01-12-2013, 10:42 PM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
most say if anything more 1/4 inch start lookin for hub centric spacers im runnin 1/4 spacer just be sure to check em everyonce in a while ther known for backin off sometimes
Old 01-12-2013, 11:31 PM
3/8" is still good and the max before you want wheel adapters. So Joel is correct.
But 3/8" works
Old 01-13-2013, 12:01 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Put them on and tighten them down. How many full turns can you get on the lug nuts? Personally I am not a fan of generic spacers, you are moving the wheel load out towards the end of the OE studs.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
Old 01-13-2013, 11:23 AM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
Even with spacers you may still rub some at full turn...
I have had 7mm (1/4") spacers on my 2007 4x4 for 5 years and no issues but I too was told not to exceed 1/4" with just a spacer and I didn't want to put an adapter on. As has been said here, you are pushing the wheel away from the truck creating more stress...but 1/4" is fine from what I can tell. I had some custom made wheel AND hub centric ones made specifically for my truck and stock wheels and they fit great...when I just used a generic spacer I had BAD wobble in the steering.
One note on the Toyo MT's though...even with 1/4" spacers mine rubbed some when turning...these are actually 35" tall (many 35s are 34.5") and they are 13" wide with those awesome looking aggressive side lugs...
So I recommend having a hub/wheel centric 7-8mm wheel spacer made...widens the track some also and looks cooler.
Have any photos of your truck? What's the setup (lift wise)?
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
