Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 01-12-2013, 06:29 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
Default First oil change done, no problem
Well after reading all these horror stories about the filter being a bitch to remove, I went and bought a Fram oil filter wrench (which is a metal socket attachment-don't buy the other brand which is graphite) and I had my 2.5lb sledge hammer at the ready. So I just put the tool on the filter and just tapped away at the socket with the hammer and it came loose easily. Then, I slipped a plastic bag over the filter and continued to un-thread it. I only had a bit of spillage. Super easy. I encourage everyone to get this tool. Its like $7. Just don't make the mistake of tightening (clockwise, of course) instead of loosening (counter clockwise) because I could see that causing all kinds of problems once you figure out you're going the wrong way. Sounds obvious but most mistakes are obvious once you realize you've made them..
Simon
Old 01-14-2013, 09:34 AM
Grubrunner's Avatar
Rep:3883
I've never removed an OEM oil filter for the first time and NOT had an issue..... certainly nothing that went as smooth as your description. Some were just damn tight and I had to work it for some time prior to coming loose; most were a complete dissmantle job and a wreck.
You did well.
Grub out!
Old 01-28-2013, 07:23 PM
LowUFO's Avatar
Rep:1105
Thanks. Yeah, everything I've ever done has taken twice as long as expected the first time. lol. This was awesomely unexpected.
Simon
