Old 01-13-2013, 02:10 PM
gmoneyRT's Avatar
gmoneyRT gmoneyRT is offline
Vehicle: 2011 Dodge Ram
Trim Level: RT
Rep:42
gmoneyRT is on a distinguished road
Default drop control arms
does anyone know if the lower control arms are the same from an 05 to 11?? reason i ask is cuz they make 2" drop control arms for 02-05 rams.
Old 01-13-2013, 10:38 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
I doubt it, but I'm not sure. Just curious, why would you want drop arms instead of springs, did you find a crazy deal on these or something?
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 01-13-2013, 11:48 PM
BLACK07 BLACK07 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT (QC/SB)
Rep:36
BLACK07 is on a distinguished road
Im almost 100% sure they are not the same (almost). I believe the year groupings are 02-05 are the same, 06-08 are the same and 09+ are the same.
From a business stand point it would make sense for a company to list the most years you can for your product so it would reach more people. It's not always the case but usually if it will fit a certain year the company will let you know.
2007 Black Dodge Ram SLT QC/SB
DIY is the way to go!
Old 01-14-2013, 07:49 PM
gmoneyRT's Avatar
Trim Level: RT
Rep:42
i do have drop spring but wanna go lower was just curious about the arms because i know the spindles push tires out....who knows maybe arms would too!! just throwin it out there!!lol
Old 01-15-2013, 12:49 AM
RAM EM's Avatar
Color: Grey
Rep:195
Only thing is, if you did find and use a drop arm, it would essentially be the same as using a spring that was 2" shorter than what you already have. A drop has a deeper "well" or "pocket" where the spring sits, increasing the depth area the spring sits in. I think you would have a very hard (or impossible) time getting the alignment back to specs. If you want a little more drop, you could cut 1/2 a coil off your drop springs and it would give you about another 1", and your at the extreme limit of getting it realigned at that point. Only way to go beyond that is spindles, unfortunately.
Old 01-15-2013, 09:52 AM
gmoneyRT's Avatar
Trim Level: RT
Rep:42
i have 3/4 of a coil cut on front and plan on doin a full coil so extra 1/4, ya ill be pushing the alignment so spindles may be my route...thanks for the input!
