Old 01-13-2013, 01:30 PM
jaybird07 jaybird07 is offline
Vehicle: 2011 dodge ram 1500
Trim Level: sport
jaybird07 is on a distinguished road
Default installing LOC stock 430n HU
im installing my audio Control LC2i line output converter, but do not know which wires to tap into on the stock alpine system..my trucks a 2011 reg cab so i was thinking of tapping into the front left and front right door speakers..anyone know which wires or colours i tap into. i got the speaker wire behind my stock 430n Head Unit just need to know where to tap them into, thanks. Please Help.
Old 01-13-2013, 05:47 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
i just have a cheap loc but i tapped into the drivers door, been pretty pretty good for me.
2011 Hemi RCSB Sport 4x4
Old 01-13-2013, 06:41 PM
Trim Level: sport
do you recall what colour wires they were?
Old 01-13-2013, 06:44 PM
Trim Level: sport
do you recall which colour wires they were that you tapped into?
Old 01-14-2013, 05:30 AM
Vehicle: 2011 Ram
Rep:141
not sure i came across and wire pinout someone on here had made, thats actually when i joined here lol to see the pics haha
Old 01-14-2013, 04:11 PM
Vehicle: 2011 Ram
Rep:141
think i went by this one....hopefully someone can confirm
22 pin connector
left to right / top to bottom
pin 1 large black wire with orange stripe (assumed ground for the amp)
pin 2 white with gray stripe (bus input)
pin 3 white with orange stripe (bus input)
pin 4 not used
pin 5 not used
pin 6 green with blue stripe (bus input)
pin 7 green with orange stripe (bus input)
pin 8 gray with blue stripe (bus input)
pin 9 gray with orange stripe (bus input)
pin 10 not used
pin 11 not used
pin 12 not used
pin 13 not used
pin 14 gray with light green stripe (RH dash speaker +)
pin 15 gray with dark green stripe (RH dash speaker -)
pin 16 gray with yellow stripe (LH dash speaker +)
pin 17 gray with no stripe (LH dash speaker -)
pin 18 green with brown stripe (LH headliner speaker -)
pin 19 green with blue stripe (LH headliner speaker +)
pin 20 gray with white stripe (sub -)
pin 21 green with white stripe (sub +)
pin 22 large yellow wire with red stripe (assumed power for the amp)
16 pin connector
pin 1 gray with purple stripe (LH front door -)
pin 2 gray with yellow stripe (LH front door +)
pin 3 green with purple stripe (RH front door -)
pin 4 green with yellow stripe (RH front door +)
pin 5 green with brown stripe (sub +)
pin 6 gray with brown stripe (sub -)
pin 7 gray with dark green stripe (LH rear door +)
pin 8 gray with light green stripe (LH rear door -)
pin 9 green with yellow stripe (RH rear door -)
pin 10 green with gray stripe (RH rear door +)
pin 11 gray with no stripe (center dash speaker, didn't check polarity...I left it stock)
pin 12 gray with orange stripe (center dash speaker, didn't check polarity.. I left it stock)
pin 13 yellow with gray stripe (RH headliner +)
pin 14 green with no stripe (RH headliner -)
pin 15 not used
pin 16 not used
