tonneaucovered.com
Old 01-13-2013, 03:21 PM
captainchubbzz captainchubbzz is offline
Vehicle: 2012 Ram 1500 5.7L Hemi
Color: Mineral Gray Metallic
captainchubbzz is on a distinguished road
Default Cold Weather, Bad Truck!
Just wanted to post and see if anyone has experienced awfully cold weather and had problems with their Ram 1500 HEMI. In Utah we had an extremely cold night, probably -16 F, just went out to start the truck as I feel bad that it was in the cold. So go to start and it bogs right down. The starter takes about 10 seconds to turn the truck over and the whole thing is shaking really really bad. About 15 seconds after running I smell gasoline. So I shut the truck off, wait a minute and start again. This time it seemed better so I put it in reverse and moved it into a sunny spot in the driveway. Let it idle for a second and the check engine light comes on flashing, the truck is still ridiculously shaky. Any ideas? With the gas smell, rough running, and flashing engine light it must be a misfire issue right. What do you guys think, maybe a frozen coilover and the plugs aren't firing correctly.
Thanks for any input!
Old 01-13-2013, 03:44 PM
wolfman01 wolfman01 is offline
Vehicle: 2013 Ram 1500 QC 4x4
Trim Level: Bighorn Edition
Rep:126
wolfman01 will become famous soon enoughwolfman01 will become famous soon enough
I have a block heater in mine, and keep it plugged in when the weather is this cold. It sounds to me like an injector may have ad a tiny piece of ice or something and stuck open, flooding a cylinder and fouling a plug. You're under warranty, so I'd make the stealership figure it out.
2014 Chevy Spark (3k)
2013 Ram 1500 Quad Cab 4x4 Hemi 8 speed (7k)
2004 Saturn ION Redline (9k)
1995 Tiffin Allegro Bay (46k)
1989 Oldsmobile Cutlass Cierra (97k)
Old 01-13-2013, 04:13 PM
Asur Asur is offline
Vehicle: .
Rep:4373
I have a 4.7 2012, last week and the week before was like -25 to - 35 for 2 weeks, never had issues, would start every morning, I do run Full synthetic, so just that helps alot. sounds like it was not breathing right. Like it was not getting any air. JMO
Old 01-13-2013, 04:25 PM
RockyRam's Avatar
RockyRam RockyRam is offline
Vehicle: 2014 Ram
Color: True Blue
Rep:851
RockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to behold
I say get a warm garage for the Ram!
Old Ram -->
Have a Gray Ram?? Join the Mineral Gray Metallic Ramz Group!!!
http://www.ramforumz.com/group.php?groupid=21
Old 01-13-2013, 06:42 PM
skull1 skull1 is offline
Vehicle: 2012 Dodge Ram Crewcab
Trim Level: Longhorn
Color: Cherry Red
skull1 is on a distinguished road
Get an OBD 2 tester and check the codes. It onlt takes about a minute and you will know Exactly what is wrong with it. If you don`t have one you can borrow one from Auto-Zone or other parts places. They can be purchased for $50 or less. It beats trying to guess.
Old 01-13-2013, 06:52 PM
AlbertaRamTruckGuy's Avatar
AlbertaRamTruckGuy AlbertaRamTruckGuy is offline
Vehicle: 2012 Ram Sport
AlbertaRamTruckGuy is on a distinguished road
I'm from northern Alberta and my truck gets started at -25 to -30 without the block heater, with no problems. It sounds like sh*t but it always runs fine, no shaking, you should take it to the dealer.
Old 01-13-2013, 08:28 PM
jacobson.s's Avatar
jacobson.s jacobson.s is offline
Vehicle: 2016 Ram 1500
Trim Level: Laramie Limited
Color: Pearl White
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:61
jacobson.s will become famous soon enough
Flashing check engine light means misfire, It has been-25C(-13F) to -35C (-31F) here a few days and I leave my truck sit at work for 9-10 hours a day and she starts with NO hesitation. Its plugged in overnight. Your truck must have an issue of some sort, the dealer will track it down. Best of luck!!!
Old 01-13-2013, 08:45 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2477
I agree that you should take it in, this does not sound right.
sales@revelperformance.com
Old 01-13-2013, 09:15 PM
Just wanted to post an update. After baking in the sun at 3 F for about 4 hours she started up just like normal and had no issues. Tomorrow ought to be a treat as tonight is expected to hit -22 F. Probably a good reason to invest in a block heater. Needs an oil change shortly so will mention this issue to the dealer and post what they say. I don't have high hopes for their insight. Thanks everybody!
Old 01-14-2013, 03:17 AM
johnnymopar's Avatar
johnnymopar johnnymopar is offline
Vehicle: 1998 in between truck GM 1500
johnnymopar is on a distinguished road
Trucks in Canada have a block heater as standard equipment I believe, at least my Laramie did. I plugged it in for the first time the other night with an overnight low of -5c and noticed it was very quite on start up and not the usual cold knock these trucks seem to have. I'd hate to hear what it sounds like in -25, lol.
