Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
tonneaucovered.com
Old 01-13-2013, 04:17 PM
Sharecropper Sharecropper is offline
Vehicle: 2003 Dodge Ram 4x4
Color: Grey
Sharecropper is on a distinguished road
Default Ball Joint Question - 2003 4x4
I have a 2003 RAM 4x4. The upper left (driver side) ball joint is in need of replacement. Is the upper ball joint on this model of truck an assembly which include the A-frame arms back to the bushings?
How difficult of a job is it to replace the upper joint assembly? Should I replace the lower as well?
Old 01-13-2013, 07:12 PM
Resident Technician
Rep:1911
Yes, you replace the arm as an assembly and it's not difficult if you have the correct tools. I wouldn't replace the lower unless it needs it. Don't forget to have an alignment done when you're finished.
Old 01-20-2013, 05:06 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
I just got done doing my uppers/lowers and tie rod ends on my truck. Upper is WAY easier then lower. If you don't need to replace lower I wouldn't. I'm not a mechanic and I was able to do it. A member on here gave me so much info on how to do that it was a breeze, till I got to lowers lol
