Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 01-13-2013, 05:45 PM
JCummings's Avatar
JCummings JCummings is offline
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
JCummings is on a distinguished road
Default Help with Tire size
I am looking for a knowledgable person who can explain to me how to figure out how changing tire size affects final final gear ratio. I understand the concept but can not figure out exactly how to do the math. I am looking to pick up a set of smaller drag tires for the truck, but I am not sure what size I am after.
Mods: Lowered and Blown.
Old 01-15-2013, 08:55 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
the sweet spot for drag tires is about 28"...I run 28" Hoosiers or 325/45-17 M&H drag radials..
Old 01-15-2013, 08:57 AM
chefred112's Avatar
Rep:656
..and I always forget to change tire size at track, dang ..I don't think it affects gear ratio as much as it affects shift points..
Old 01-15-2013, 09:02 AM
chefred112's Avatar
Rep:656
here is a simple calculator.... plug in stock tire diameter and current gear ratio and new diameter to compute new ratio..
http://www.rocky-road.com/calculator.html
Old 01-15-2013, 09:06 AM
chefred112's Avatar
Rep:656
but, plug stock tire dia in 'new' tire dia and proposed drag tire dia in 'old' tire dia field ... the guy mislabeled the fields...
Old 01-15-2013, 06:16 PM
JCummings's Avatar
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
Thx guys. Are you running 1/4 mile or 1/8th? What rpm and gear are you crossing the traps at?
Old 01-15-2013, 07:19 PM
chefred112's Avatar
Rep:656
run both the 1/8th (7.8x) and 1/4 (12.1x), I know I'm in 3rd when i cross in the 1/4 and I think I do in the 1/8th as well as i don't think I can be in 2nd at 90+ mph. And I want to stay out of 4th at the 1/4...
Old 01-15-2013, 09:24 PM
JCummings's Avatar
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
Fred, I only have a 1/8th mile track near me. I think that I would like to be topping out 2nd prime when I am crossing the finish. What are your thoughts? I know that you have much more experience than I do. Also, I plan on installing a super charger within a year. I am planning aloof my mods around that setup. Thanks again, joe
Old 01-21-2013, 07:47 AM
JCummings's Avatar
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
Anyone have any knowledge on this matter?
Old 01-22-2013, 07:08 PM
chefred112's Avatar
Rep:656
I hope 2nd prime is more stable in your 4th gens then it was on our 3rd gens...we would at all cost try to avoid 2nd prime because it eats transmissions (I should know)..we would only be able to access on downshifts anyways, not on upshifts..
