Old 01-13-2013, 08:51 PM
Silverfang Silverfang is offline
Vehicle: 2013 Dodge ram sport
Trim Level: 1500
Color: Maximum steel metal
Silverfang is on a distinguished road
Default Cold air intake
I'm looking to put exhaust and cold air intake on my 2012 5.7 HEMI sport . But I can not get a clear answer about keeping the warranty warranted after installing a cold air intake .does anyone know of a brand of cold air intake that will be aloud by Chrysler ?? Thanks for the help,
Old 01-13-2013, 09:22 PM
Bully's Performance's Avatar
Bully's Performance Bully's Performance is online now
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Chrysler can not void you warranty due to aftermarket parts unless they can prove that part is what caused the issue
Thanks
Jeremiah
Discount Auto Performance
Old 01-13-2013, 10:20 PM
clum553946 clum553946 is offline
Vehicle: 2012 Ram Big Horn Crew 4X4
Rep:24
clum553946 is on a distinguished road
How would they know if you put the stock box back on when you go to the dealership?
Old 01-13-2013, 10:29 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
If you put the stock box back in before going to the dealership they wouldn't be able to tell, however i have had many vehicles into chrysler for warranty work with an aftermarket cold air intake and they have never said anything about it
Thanks
Jeremiah
Old 01-13-2013, 10:31 PM
Grubrunner's Avatar
Rep:3883
Putting the OEM setup back on every dealership visit is a tedious process.
In all the years of surfing and being active on boards of this nature, I've never seen a case of an aftermarket air intake causing any issue where a warranty battle was the result.
To answer the OP's question: I believe Mopar makes an aftermarket air intake that will fall into the category you're concerned about. Many here have it with nothing but praise....for the most part. I believe it's a rebadged air intake from another manufacturer.
Good luck ultimately in your decision.
Grub out!
Old 01-13-2013, 10:32 PM
Trim Level: 1500
I was told if you bring your truck in with any engine knock . They will take an oil sample and get it analyzed and some how cold air intakes will leave more oxygen traces in the oil
Grubrunner's Avatar
Rep:3883
....oh and welcome to the boards.
Grub out!
Old 01-13-2013, 10:35 PM
Grubrunner's Avatar
Rep:3883
The link below may help --
http://www.ramforumz.com/showthread....par+air+intake
A search will also yield countless results.
Grub out!
Old 01-14-2013, 01:01 AM
Trim Level: 1500
Thanks for all your info this far
Old 01-14-2013, 02:18 PM
imlikeojnow imlikeojnow is offline
Vehicle: 2006 Dodge Ram Big Horn
Trim Level: SLT Big Horn
Color: Blue
Rep:33
imlikeojnow is on a distinguished road
pretty sure we can send that one to myth buster. temp of air has nothing to do with the oil.
