Old 01-14-2013, 11:09 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Exclamation What cable do i need for ipod integration?
I have a single disc res radio with the u connect, i know this because i can make phone calls through it haha. but what ipod integration cable do i need? There is so many different ones and i can figure it out. Thanks for the help!
Old 01-14-2013, 11:36 PM
Rep:2657
I suggest that you read this post, mostly page 2
XSDBS is the radio guru, he knows Ram radios
http://www.ramforumz.com/showthread....ini+ipod+cable
Old 01-14-2013, 11:59 PM
Ryank's Avatar
Rep:199
Thanks! i read through it, kinda helped, it helped me figure out that my truck doesnt have the usb cable already, so i need to figure out what cable i need to buy!
Old 01-15-2013, 12:16 AM
Rep:2657
I don't know for sure, but i believe it is called a MINI USB cable, about $8
don't get a short one, you want a bit of extra length
If i read the other post correctly, the RES has to have the module to plug the cable into
If you remove the lower glove box by pushing in on the sides & pulling it towards you, then look under the upper glove box for a single screw, remove it, then remove the upper glove box, you should be able to see any module, hopefully it will have the plug in port on it
OR you can just pull out the radio & look around for it, maybe 7 screws
Old 01-15-2013, 12:22 AM
Rep:2657
someone else is having the same issue, they just now posted
& the answer they received was
On the module there is a mini USB connector, you'll need the iPod / USB cable PN 82212160. This cable will have a USB connector on it where you'll plug in your iPod docking cable.
http://www.ramforumz.com/showthread.php?t=130096
Old 01-15-2013, 12:44 AM
Ryank's Avatar
Rep:199
Thanks! ill look tomorrow and see if the cable is coiled up behind by chance! IM just hoping theres some way to integrate, i really dont want to buy a whole new radio haha
Old 01-15-2013, 01:30 AM
Rep:2657
the next radio up would be the HIGH SPEED RBZ 430 non navigation
some members are selling theirs fairly cheap $350
again you would need the ipod cable, i am not sure, but it may be this one
http://www.oemautopartsco.com/index....p_image&pID=10
Old 01-15-2013, 01:10 PM
Ryank's Avatar
Rep:199
Thanks for the help! I'm going to the dealership today to see what they say.
