2012 ram battery light - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 01-15-2013, 01:49 PM
jgrady jgrady is offline
Vehicle: 2012 dodge ram
Trim Level: express
Color: blue
jgrady is on a distinguished road
Default 2012 ram battery light
lit up. Not on 2009 wiring diagrams at all,assume driven by ECU? /PCM. charging system is perfect. Help from site, top shelf, got me to 09 wiring, but this light not on that diagram.Trying to find out what drives it. Starting to think lit by CAN bus into cluster? Are all the idiot lights lit that way? No diagram of cluster itself, or how it works??
Ready for black tape over light. Do not want them pulling truck apart.
Old 01-15-2013, 10:35 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Good luck and please keep us updated on how you make out.....
Old 01-15-2013, 11:53 PM
itshertruck's Avatar
itshertruck itshertruck is offline
Vehicle: 2016 Dodge Ram 1500 CC
Trim Level: Rebel
Rep:15
itshertruck is on a distinguished road
Send a message via AIM to itshertruck
I have a 10, my light came on and truck died. Have you had any starting issues? I had a bad battery from the factory. Just a thought.
If it's too loud, You're too old!!
Dodge the father and RAM the daughter!!!
Old 01-16-2013, 04:03 PM
JAC65's Avatar
JAC65 JAC65 is offline
Vehicle: 2010 Ram Laramie 4x4 Crew
Color: Mineral Gray Metallic / Light Graystone PC
Rep:12
JAC65 is on a distinguished road
Have you checked the voltage output from the battery? Alternator? Despite the charging system working, if your battery and or alternator has and undervolt or overvolt condition that is "out of spec" it could be causing the fault.
Old 01-17-2013, 03:54 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
This is what the owners manual states about your symptom:
32. Charging System Light
This light shows the status of the electrical charging
system. The light should come on when the
ignition switch is first turned to ON/RUN and remain on
briefly as a bulb check. If the light stays on or comes on
while driving, turn off some of the vehicle’s non-essential
electrical devices or increase engine speed (if at idle). If
the charging system light remains on, it means that the
vehicle is experiencing a problem with the charging
system. Obtain SERVICE IMMEDIATELY. See an authorized
dealer.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
