Old 01-15-2013, 02:12 PM
macedog's Avatar
macedog macedog is offline
Vehicle: 2010 ram sport crew cab
Trim Level: sport
Rep:32
macedog is on a distinguished road
Send a message via AIM to macedog
Default 2013 dodge ram headlights
does anybody know if the new headlights fit the 2010 rams?
Old 01-15-2013, 05:45 PM
bighemi04's Avatar
Rep:623
Yes they do. A member on did that mod. Check it out
http://www.ramforumz.com/showthread....114803&page=30
Old 01-15-2013, 05:56 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Guess what i found today OEM PART NUMBERS!!!!
sport (black)
68093220-AB
68093221-AB
Premium(Chrome)
680932216-AB
68093217-AB
Thanks
Jeremiah
Discount Auto Performance
Old 01-15-2013, 10:52 PM
rickruiz830 rickruiz830 is offline
Vehicle: 2010 Ram 1500 sport
rickruiz830 is on a distinguished road
I'm wanting to do it to mine as well. Let me know how it is when you put them in. And where can you find them?
Old 01-15-2013, 11:40 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Best bet right now to the best of my knowledge would be ebay, or strait from the dealer, however from the dealer will run you a little over 1000 for the sports, tomorrow i am going to reach out to a few oem "like" manufacturers and see what they have cooking in the factories in regards to these and to see if i can maybe get a time frame when they might be releasing oe replacements I will let everyone know what i find out.
Thanks
Jeremiah
Old 01-16-2013, 04:09 PM
macedog's Avatar
Trim Level: sport
Rep:32
see if maybe you can start up a group buy and get them cheaper for all of us!!!
What is with having to rewire them? looks like a big hassle
Old 01-16-2013, 04:23 PM
macedog's Avatar
Trim Level: sport
Rep:32
do you know if they make a fog light to match?
Old 01-16-2013, 04:39 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Yes they fit. The only issue you will have is the adjusting screw. They moved it in 2013 so in order to adjust them you have to push the headlight in and see where its at. Then pull it out, adjust, put it back in and repeat till you get the beam where you want it.
The closest matching fog light setup you can get is a retrofit. I ordered one and am waiting for it to be built.
Go to retroshop . us and you will see what I am talking about.
Also it should be noted these headlights do not plug right up. You will have to do your own wiring and either get the right connector from dodge or do your own mini connectors. Either way you will be cutting into your stock wiring harness.
Currently I haven't found JUST the connector for sale yet.
Chrome... in moderation.
Old 01-17-2013, 10:27 AM
macedog's Avatar
Trim Level: sport
Rep:32
those white head lights are so sexy!
but thanks for the great info and those fog lights are so sweet! can't wait to see those on the truck
Old 01-17-2013, 11:06 AM
bighemi04's Avatar
Rep:623
i was crusiing around ebay and came across this. Kind of interesting
http://www.ebay.com/itm/NEW-MOPAR-20...item27cdb5ac3e
