Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 01-15-2013, 04:43 PM
Shadyd4 Shadyd4 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Crew Cab Slt Sport
Shadyd4 is on a distinguished road
Default Ball Joints
So I have around 95000 miles on my truck and the ball joints are popping pretty bad so I have called around and the guy at the parts place says moog doesn't make them for the 2009 so I need to call the dealership. Which I do and the guy tells me I have to buy the whole arm for upper and lower and the cost is 160 or so for the top and 350 or so for the bottom. Is that the only way because it seems to me that they should press out like any other vehicle.
oh and hey to everyone..
Old 01-15-2013, 04:56 PM
simonmw75 simonmw75 is offline
Color: Graphite
Rep:72
simonmw75 will become famous soon enough
I took a quick look on the RockAuto.com website, and it looks like they have ball joints for the 09.
Old 01-18-2013, 01:31 AM
mastertech10 mastertech10 is offline
Vehicle: 2013 RAM 1500
Rep:12
mastertech10 is on a distinguished road
Hey ive done a few lower control arms due to the lower ball joints failing. And yes mopar does not do them seperate. 2wd nor 4wd joints are only complete with the arms.
You might be able to get an aftermarket kit, but if it dont work make sure you have a good welder!!
Old 03-19-2013, 10:43 AM
found out it wasn't the ball joints popping. it was a brace underneath 2 bolts came loose and when i turned it moved and popped. sounded the same as ball joints though.
Old 03-24-2013, 09:29 PM
hammerhead123 hammerhead123 is offline
Vehicle: 2007
hammerhead123 is on a distinguished road
what year make and model do you have?
I have a 2007 Ram 2500 and just noticed today that when I turn, it started making a popping noise
