Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
United Radio
Old 03-25-2013, 02:53 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Default Leaf Pack Question
The question is this If I take my truck (2500HD 6.7 Crew Cab) and have someone re-ark the leaves 3" over stock will that be technically a 3" lift then I can add Bilstein 5100 to the front or the Bilstein/fire stone air shocks would that work without damaging anything I do tow a 30' trailer and my truck is a daily driver.
Thanks For the help
Old 03-25-2013, 05:14 PM
Lifted Cummins Fanatic
Rep:2026
I'm not overly familiar with the 2500 suspension set up but from what I have seen they have coil suspension on the front and leafs on the back. So are you wanting to just re-ark the back leafs for 3" of lift? That would give you a ridiculous amount of rake in my opinion. If you're looking for better stance I would either go with a leveling kit or get a proper lift kit to lift the entire truck. I figure half assing it is never the way to go... especially on your $60,000 truck. And if you are towing a lot you definitely want something that's going to stand up to that and work properly.
Old 03-26-2013, 08:30 AM
Iqudayo's Avatar
Rep:563
I do have a leveling kit on the front I also want to raise the front with either Bilstein 5100 adjustable shocks of the Bilstein/Fire Stone air bag shocks 2' maintaining my stance.
These; http://www.truckspring.com/products/...tem__1004.aspx
lift question
