Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 02-04-2013, 06:40 AM
DarthVenom's Avatar
DarthVenom DarthVenom is offline
Vehicle: 1997 Ram 2500 V10 4X4 Ext. Cab
DarthVenom is on a distinguished road
I have a 97 2500 V10 4x4 and my radiator leaks up at the top drivers side corner just to the right of where the top hose connects to the radiator.
The reason your leak (like mine) is happening randomly is that once yur coolant level drops below the leak your engine will still stay cool and you will only notice a problem if you park sideways on a hillside with the drivers side of the truck at the lowesr point allowing more coolant to leak out.
These radiators seem to be weak in this area. Also, my 97's underhood configuration is just like how you describe your 99.
How I stopped my leak is with a good bottle of stop leak. You'll have to give this time to work so keep some water handy and check your coolant level often
Hope this helps.
1997 Ram 2500 4x4 V10 Extended Cab
8" Lift, 12.50 x 35 LT'S on 17 x 10 " Alloy Wheels.
