46re - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 01-15-2013, 06:44 PM
benji36's Avatar
benji36 benji36 is offline
Vehicle: 2002 ram 1500
Trim Level: slt 4x4
Color: burgandy
benji36 is on a distinguished road
Default 46re
Hi, New to this forum stuff.But I need some help with my 02 1500 RAM 5.9 SLT.The other day with no warning she lost reverse,pulled the trans pan and the rev servo piston looks cracked.I took the valve body out thinking that after backing the band adjuster off I could take the strut out ,but it doesnt look like the strut will come out unless I remove the pin going though the adjuster and strut.Is the strut one part on the newer 46re.Really hate to pull trans apart just for a servo.Thanks for any help.
Old 01-15-2013, 06:56 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Welcome to the Z you will find many knowledgeable members here, if you have any questions feel free to ask. Additionally if there is anything i can help you with let me know.
Check out some of the most popular 3rd and 4th gen(2002-2012) mods just click the name of the item
Lowest prices around
DiabloSport/Bully Dog/SuperChips programmers and tuners
CAT-BACK PERFORMANCE EXHAUST SYSTEM BY MAGNAFLOW
AMP RESEARCH POWERSTEP 2002+
FoldUp and Roll up Bed Covers!
Level Kits 2009+
Bilstein 5100 Height Adjustable Shocks
Performance Accessories 3 Body Lift 2002+
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 02-17-2013, 02:49 PM
benji36's Avatar
Trim Level: slt 4x4
Color: burgandy
Default 46re servo
Ok, I ended-up pulling the overdrive so I could get the adjuter pin out and replace the rev/first servo.When I pulled the overdrive peices of snapring fell out,the one that holds the overdive clutchs in.Went to local trans shop and got the parts.The guy said the snapring was a common problem for Dodge and the servo breaks because the rev/first band was was out of adjustment. She is shifting fine now. But now the speedometer is not working .Codereader came up with no signal from vehicle speed sensor ,replaced sensor still no speedo.Getting 2.5 volts at sensor plug . Anybody got any ideas.
Old 02-18-2013, 05:19 PM
benji36's Avatar
Trim Level: slt 4x4
Color: burgandy
Default 46re servo
Turns out the abs speed sensor on diff. and the speed sensor on overdrive use same ground wire.Check the abs sensor just to elimnate it as problem and the top of sensor had came off halfway,pushed it back on and speedo started working.Engine light went and problem solved.
Old 02-18-2013, 05:30 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
Thanks for the update!
Old 02-18-2013, 09:11 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Glad you got her fixed.
Old 02-19-2013, 07:54 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
welcome to the forum. you might have just become the go to guy on the 46re.
Old 02-19-2013, 09:41 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
This could work. You have a problem. You solve the problem. You post the solution. I like that!
