Help with heater problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 01-16-2013, 12:37 PM
semperfi's Avatar
semperfi semperfi is offline
Vehicle: 2016 3500 Big Horn 4X4
Color: True Blue Pearlcoat
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:18
semperfi is on a distinguished road
Default Help with heater problem
Most night have been below zero for the last month and this morning drivers side and defroster just blows cold air. The passenger side blows warm air. Is this a fix I can do instead of going to the dealer which is 3 hours away.
Thanks
2016 3500 Big Horn 4X4 6.7 Cummins Aisin 6 Speed
2014 2500 Longhorn 4X4 6.4 Hemi Traded
2012 1500 Longhorn 4X4 5.7 Hemi Traded
Old 01-16-2013, 12:47 PM
Resident Technician
Rep:1915
Does your truck have single or dual zone climate control?
Old 01-16-2013, 01:03 PM
semperfi's Avatar
Rep:18
It is duel zone and is on sync.
Old 01-16-2013, 01:29 PM
Resident Technician
Rep:1915
It's likely either a blend door problem or a heater core issue. Both will require a trip to the dealership. Is there not a Chrysler dealership of any kind closer than 3 hours from you?
Old 01-16-2013, 01:32 PM
semperfi's Avatar
Rep:18
Thanks I guess its off to the Dealer
Old 01-16-2013, 02:42 PM
semperfi's Avatar
Rep:18
It is now working, it was 12below this morning could one of the gates just froze shut??
Old 01-16-2013, 03:02 PM
Resident Technician
Rep:1915
Seems unlikely that it literally froze, but there could definately be a problem that kept the blend door from moving. The HVAC head may have stored a code for the problem. I would still recommend having the dealer check it sometime just so you can have the complaint documented in case it happens after your 3/36 coverage expires.
Old 01-16-2013, 03:55 PM
semperfi's Avatar
Rep:18
Thanks again for your help
