Old 01-16-2013, 11:59 AM
jtheruler79 jtheruler79 is offline
Vehicle: 2012
jtheruler79 is on a distinguished road
Default adding hidden cigarette socket
I'm wanting to add a cigarette socket under the dash to for my GPS to hide the wires and really dont want to run a in-line fuse to the fuse box under the hood. What is the easiest way of doing this? Is is okay is I splice into the existing factory cigarette lighter socket? I've never done this before and would like some advise.
Old 01-16-2013, 12:04 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2012 Ram 1500 Crew
Color: Black/Silver
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
If you are going to splice into existing wire and want to do it without cutting them, I came across a very nice splicer called a Posi-Tap. They work very well, easy to use and look good in visible locations. Here is the link:
http://www.posi-lock.com/
Hello, my name is Tim and I'm a modaholic.
MODS: 6" RCX Lift, 37"X12.5R20 Trail Grapplers on 20" Moto Metal 962 Black/silver rims, remote tailgate lock, Bakflip G2 tonneau cover, LineX spray-on bed liner, Amp Research Power Step, magnaflow 18" muffler, S&B CAI, Passenger Front Ejection seat, Diablosport Trinity1000 tuned with Hemifever 89 tune, Spyder Projector/HID 8000K/CCFL Halos/LEDs Headlights, Retroshop Projector/HID/8000K/CCFL Halo Fog Lights, Recon LED Smoked Tail Lights & LED Smoked 3rd Brake Light, fully stocked bar w/tap, BT Catch Can, Chrome & Black Mesh studded Grille, HID Reverse Light Kit, customized tailgate badge....more to come!
Old 01-16-2013, 12:11 PM
Vehicle: 2012
Those look very easy to use. Thank you! Splicing into the existing socket shouldnt cause any issues, correct?
Old 01-16-2013, 12:30 PM
TVL's Avatar
TVL TVL is offline
Color: Black/Silver
Rep:147
As far as I know, it shouldn't cause issues. I haven't spliced into the wire for lighter socket on a vehicle in many years! You may want to ask RamTech if there would be a problem. More than likely it won't hurt anything. You're just splitting off the power to another load. I doubt there is anything in the BCM that would be affected.
Old 01-17-2013, 02:56 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
I doubt your GPS uses much juice? Maybe 1A? Check how much it uses. Then check the fuse rating of the OE lighter. I'm sure you'll be fine. Do you have the trailer brake controller? That's where I tapped into for my radar detector hardwire. There's many live +12V under your dash, but it was difficult finding a keyed +12V.
Old 01-17-2013, 03:01 PM
Grubrunner's Avatar
Rep:3883
Your cigarette lighter is a switched ACC 12V source.
Look for a constant 12V source so you can still use your navigation's features without requiring the key to be in the ignition.
Grub out!
