Adding Uconnect rearview mirror - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 01-16-2013, 01:06 PM
jtheruler79 jtheruler79 is offline
Vehicle: 2012
jtheruler79 is on a distinguished road
Default Adding Uconnect rearview mirror
Has anyone added the Uconnect reaview mirror part #55157457AC? I just ordered the Uconnect kit and 430 RBZ and really would like to add this mirror. Does the mirror include auto-dimming? Is there just one cable that runs from the mirror to the Unconnect box? I hoping that once I remove the basic stock mirror the new one will slide right on.
I was told by an online dealer that this mirror would only work with NAV units, is this correct?
Old 01-16-2013, 02:39 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
The mirrir came on my 2009 with the RES radio, was wired into the UConnect module.. When I changed out the RES to an RHR radio (730n) I had to get another cable and wire the mirror directly to the back of the RHR radio.. I also had to disconnect the UConnect module because it was built into the radio. It worked with either setup.
I believe you will still need the Uconnect module with the 430n radio and it will still get wired into the module.
The mirror does include auto dimming.
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 01-16-2013, 03:08 PM
Vehicle: 2012
Thanks for the information, Andy! Do you happen to still have the cable you removed? If so, could I purchase it from you?
Jason
Old 01-16-2013, 04:47 PM
astroman54's Avatar
Rep:52
I didn't remove the old cable, because the one end of the new cable was a "y" connector setup where it went between the original connector and the mirror, and the other end I had to route to the back of the radio.
Sorry,
Andy
Andy
Old 01-16-2013, 05:11 PM
Vehicle: 2012
I see that the harness has two connections, one to the radio and I'm not sure where the other one goes. Any ideas? Is it the connection for auto-dimming?
Old 01-16-2013, 08:03 PM
astroman54's Avatar
Rep:52
The auto dimming is built into the mirror. It requires power (+12v) and ground, and then there is about 6 wires for two microphones that need to go to the Uconnect module (all radios but RER and RHR) or the back center connector of the radio (RER and RHR radios only). It also gets wired into the reverse light circuit so the dimming will go away while backing up.
That's all I can remember off the top of my head.
Andy
Andy
Old 01-17-2013, 11:08 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
I'll just throw this out there for you to chew on. The mic in the rear view mirror is the absolute worse location for the mic. You will have better VR command recognition as well as people being able to hear you better by putting an external mic on the "A" trim area near the drivers visor.
Old 01-18-2013, 03:43 PM
astroman54's Avatar
Rep:52
Agreed that the placement isn't the best location. Perhaps the absolute best would be the center of the steering wheel, but the air bag preempts that. I replaced the OEM mirror with one that had a monitor in it for my reverse camera. I just had to add two wires for that.. And then I opened the mirror and added two microphones to the front face so I didn't have to rewire the truck to put the microphones elsewhere. It still doesn't like having the heater on defrost very much.
Andy
Andy
Old 01-23-2013, 11:13 PM
Encr1pt10n Encr1pt10n is offline
Vehicle: 2012 Ram
Encr1pt10n is on a distinguished road
the rear view mirror you ordered should all be plug and play with the RBZ unit. On the back of the RBZ it should just plug right in, although a trip to the local dealer may need to be in hand of course. What head unit are you upgrading from?
Old 01-25-2013, 10:16 AM
astroman54's Avatar
Rep:52
The RHR and the RER are the only two radios that have the Uconnect system built into the radio and require that the mirror be connected directly to it. The RBZ and all other radios utilizes the Uconnect module that the mirror plugs into and does all of the voice recognition commands and bluetooth.
Andy
Andy
