Turning on Driving Lights with High Beam via Relay - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 01-16-2013, 01:12 PM
MontanaTom MontanaTom is offline
Vehicle: 2001 Dodge Ram 1500
MontanaTom is on a distinguished road
Default Turning on Driving Lights with High Beam via Relay
Hi guys! I'm trying to install some driving lights that turn on with my high beam via a relay! Normally you just connect a wire to the high beam side of the headlight connector to the relay and when the high beam comes on the relay trips and turns the driving lights on. HOWEVER, that doesn't work on the 2001 Dodge Ram 1500 I have as there seems to always be power to the high beam postive wire. It's like they switch it on and off via the ground side or something. Any ideas? It looks like it would work on the low beam side, but with the lights I have that wouldn't make sense! :-) Thanks for feedback!
Old 01-16-2013, 04:16 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Let us know how you make out and please keep us updated.
Old 01-16-2013, 04:28 PM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
Can you find where the lights ground?
If so, then tap the line after the switch and before it grounds.
driving lights, high beams, relay
