I Discovered a New Wire Connector! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Product Reviews
Product Reviews Have you found a great product, or a really bad one and you just need to tell someone about it! Post up a review for the benefit of all!
Old 01-16-2013, 02:23 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Default I Discovered a New Wire Connector!
I recently ordered and installed the Amp Research Powerstep. It came with wire connectors called Posi Taps. They are awesome! So easy to use! I was skeptical at first because if it's not a pain in the ass to use, it probably doesn't work very well.
I was so excited when I used these I almost wet myself.
Maybe I'm late to the party and everyone knows about these, but I thought I would share the product with you guys. Here is a link and the picture. They have a few different kinds for different applications and different wire sizes. Happy Modding!
http://www.posi-lock.com/index.html
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 01-16-2013, 02:36 PM
Resident Technician
Rep:1915
I've seen something similar before. They look like a good idea for light amperage loads.
Old 01-17-2013, 02:36 AM
TVL's Avatar
TVL TVL is offline
Rep:147
Yes, I was amazed at how easy to use they are even in tight spaces. They seem very secure once you tighten them!
