Has my truck been lifted? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 01-17-2013, 01:41 PM
Lowrdr's Avatar
Lowrdr Lowrdr is offline
Vehicle: 98 1500 Laramie SLT 4X4 QuadCB
Trim Level: Laramie SLT
Rep:13
Lowrdr is on a distinguished road
Default Has my truck been lifted?
Hi, I purchased a 98 1500 4X4 and was looking to level the ride. I measured the distance from the ground thru the middle of the tire to the top of the wheel well. The front is just about 37.5" and the rear 39.75".
Does this seem about right for stock? There is quite a bit of space between the top of the tire and the lip of the wheel well. I just bought this truck last summer, do you think it has been modified/lifted at all? How could I tell?
Thanks for reading
Old 01-17-2013, 01:47 PM
Designflaw's Avatar
Designflaw Designflaw is offline
Vehicle: 2013 Ram 1500 4x4 Sport
Rep:40
Designflaw is on a distinguished road
Looks stock, but would need to see a picture from the underside at lift locations
2013 CC Sport 4x4: 3.55, 20% Tint, Line-X, fender flares, mud flaps, Weather Techs, bed cover, 2.5 Leveling kit, Blacked out emblems, Vararam Air Grabber
2008 M109R LE, 1999 TL1000R, 2003 Yamaha Golf Cart :hah:
Old 01-17-2013, 01:49 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
From the second picture I want to say it's not stock. but i'm not familiar with that year truck. What i DO know is...you need some bigger tires on that bad boy, those tires there look so tiny.
nice lookin ride tho!
Old 01-22-2013, 01:04 PM
Lowrdr's Avatar
Rep:13
Agreed on the tires, just getting into my truck; first one. Lots of things vying for my money, I can't replace the tires until these are used up. I use to spend all my money on my boat and motorcycle and my wife is non to happy I added a truck to the list.
Old 02-27-2013, 04:56 PM
dapepper9's Avatar
dapepper9 dapepper9 is offline
Vehicle: 2001 Dodge Ram 1500
Color: Emerald Green
dapepper9 is on a distinguished road
I dont believe it has been lifted. Mine is an 01 of the same model. I'm pre sure, don't take my word on it as I'm not 100%, but I believe they just had a bit higher ground clearance right out of the factory.
Mods: F&B 52mm, M1, JBA SS Headers, FRP SCT tuning, HID Retrofit IG: TylerPhelps15
Old 02-27-2013, 08:20 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Those look about stock height. The smallish stock tires kinda make it look bigger If I had a tape measure here, I'd measure my truck to compare even though mine sits up higher with the Offroad Package.
Here's mine as a reference with 33's and the OR package:
Old 03-07-2013, 11:01 AM
TinMan68 TinMan68 is offline
Vehicle: 2013 Dodge Ram 1500 Express
Trim Level: Express Quad Cab
Rep:48
TinMan68 is on a distinguished road
I think to get a closer idea you should measure from the center of the axle to the wheel opening lip. If you take it from the ground different size tires will make a great difference in the measurements. I just measured mine both ways. Mine is bone stock with 285x70x17 tires. It has the offroad package too and the build sheet tells me there's 2 inch body lift with that. Being as mine also only has 26,000 miles I'm guessing its close to stock given its packages. From center of axle to wheel opening lip front is 25" and the rear is 27". From the ground to the lip mine is 39.5" on the front and 42" on the rear. Hope this helps!
2013 Dodge Ram 1500 Express Quad Cab 5.7L Hemi With 6 Speed Automatic And 3:55 LSD Gears and 20 Inch Rubber
2002 A6 3.0L 30V Quattro Avant Auto
2003 Nissan 350Z Enthusiast Model 6 Speed Manual
