Old 08-12-2013, 10:57 PM
pvm171's Avatar
pvm171 pvm171 is offline
Vehicle: 2013 ram 1500 longhorn
Trim Level: longhorn
Color: western brown
pvm171 is on a distinguished road
My 3013 Longhorn has the USB under the cover in the upper console as yours - only have one 12v which is in console - goes off
The rear 12v outlet also goes off with ignition
I am having to run hot 12v from battery just to power 10 amp braking system used when towing behind motorhome - a real pain
Old 08-13-2013, 06:48 AM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
My 12 volt in my fold down center console stays hot now that I changed the fuse position. I have the center seat with buckets.
Aepowell Sherman,TX.
Old 08-14-2013, 12:53 PM
rjmlakota's Avatar
rjmlakota rjmlakota is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:18
rjmlakota is on a distinguished road
Originally Posted by tev9999 View Post
Just checked my fuse box and manual. The back seat power outlet is selectable - the front is not.
The attached photo shows the two fuses circled. The one on the right is for the back seat has two positions - the position it is in is for always hot. I moved it to that position and confirmed it is now hot when the truck is off.
The one on the left is for the center console and as you can see, cannot be moved.
Note the top of the picture is towards the windshield.
tev9999 - Thanks a bunch for showing us this mod!! I moved the fuse last night and my rear 12v outlet works like a champ when the truck is off!!!
Old 08-29-2013, 10:49 PM
biesek2006 biesek2006 is offline
Vehicle: 2013 Ram
Color: Maximum Steel
biesek2006 is on a distinguished road
I have two on the dash the one closest to the drivers turns off with the key the other one stays on
Old 08-30-2013, 05:42 AM
dawoodsman dawoodsman is offline
Vehicle: 2013 Ram 1500 Crew
Trim Level: Outdoorsman
Color: True Blue Peal/Mineral Gray
Rep:92
dawoodsman will become famous soon enough
Not sure why they both don't act the same way, but the whole issue is to keep you from draining your battery--which can happen in no time with some appliances left plugged in and it's hot when the truck is off.
I think the standard ac plug one is hot when off. In any case, one of them (I think that one) is hot when off, BUT it will shut off automatically a set time after your truck is shut off--again, to save you from draining your battery down. I don't know for certain but I bet a note comes up on EVIC when this happens.
For folks with old timers disease like me---who don't use the things often enough to keep it straight--you can just look at the symbols by each plug in.
Old 08-30-2013, 09:09 AM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
Glad you posted this with the picture and glad I found it. Finally got my truck and one of the first disappointments was to find there is nowhere to plug in my ARB fridge/freezer. My Longhorn only came with two outlets, both keyed hot only - or so I thought.
I have already checked my manual, both the printed one that came with the truck and the one on CD and had not found anything about this fuse either. Guess I wasn't looking in the right sections.
Planning a long dirt drive on Sunday with the family after I finish up some mods and was thinking I was going to have to revert to old fashioned ice and cooler until I could find time to install a new always hot outlet.
Will eventually install a couple more outlets anyway, with heavy guage wire for low voltage drop and high amp draw, including at least one in the bed, but for now, this is just the ticket!
- DAA
Old 09-05-2013, 12:02 AM
pvm171's Avatar
Default Hot 12 volt
Boy this information really helped me.....I needed an always hot 12 volt for my aux brakes while towing and was in the process of running a hot wire from the battery through the firewall ....moved the fuse and wola !
Old 09-09-2013, 11:18 AM
katokahn99's Avatar
katokahn99 katokahn99 is offline
Vehicle: 2013 2500 CTD Laramie Mega 4x4
Color: Black Gold Pearlcoat
Rep:14
katokahn99 is on a distinguished road
Does this fuse mod work the same for the 2500? If so, which fuse is it?
