Newbie Needs Assistance - Trans Fluid & Spark Plug - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 01-17-2013, 07:11 PM
woodtoolguy woodtoolguy is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: SLT Reg Cab, 8' Box
Color: Deepwater Blue Pearl
Rep:48
woodtoolguy is on a distinguished road
Default Newbie Needs Assistance - Trans Fluid & Spark Plug
First, let me express my gratitude for the collective knowledge on this forum. Been lurking for nearly a year (with membership). The volume of information I've gained is incredible.
I'm about to start my 30k service & I'm doing it myself. Having done all of my own oil changes I must say that I'm no mechanic, just an experienced home DIYer. Before beginning, I've got 2 questions:
1) When adding/refilling transmission fluid, the new fluid goes into the transmission dipstick tube, right? I see no separate fill, like for the engine oil change.
2) What size do I purchase for the spark plug socket? I'm using NGK standard copper (LZFR5C-11). They're on their way from RockAuto.com and I want to purchase the socket before the plugs arive.
Also, if anyone can recommend a good spark plug socket to use, I would appreciate it. I've got a good assortment of extensions & u-joints in 3/8" and 1/2" drive.
Thanks.
woodtoolguy
Old 01-17-2013, 07:59 PM
bighemi04's Avatar
Vehicle: 2017 1500 Laramie
Rep:623
I would buy, actually i did lol, a magnetic spark plug socket. Is the trans service really at 30k now? My 04 was 100k, but yes that is where you put their fluid in.
Old 01-17-2013, 08:07 PM
Rep:2929
Look at your Owners Manual, your transmission does not need servicing yet, unless you use it as a taxi, considered heavy duty service
The fluid is put in the transmission dip stick, when it is needed
Spark Plugs all used to be 13/16th socket size
Lately more & more of them are 5/8ths socket size
because of the tight fit, i suggest using a piece of straight rubber hose to remove the old plugs, after they are loosened
Use the same hose to start the threads on the new plugs, use a dab of Anti Seize too
i use a tool that is made just for spark plugs installation & removing, the large end is for your hand, the small end slips over the spark plug
http://www.mactools.com/shoponline/p...g-starter.aspx
http://www.summitracing.com/parts/wm...0/media/images
Old 01-17-2013, 09:00 PM
Rep:48
Default Thanks!
Thanks guys.
I'm changing my transmission pan to a mag-hytec unit, that's why I'll need to refill the transmission fluid.
While at it, I'm installing a mag-hytec rear diff cover also.
Got the rubber tube tip covered for the spark plugs. Using a 6" section of 3/8" air line hose.
Guess I'll have to wait for the plugs to arrive to be sure.
woodtoolguy
