Old 01-18-2013, 06:06 AM
Nck's Avatar
Nck Nck is offline
Vehicle: Superb 1998 Dodge Ram
Trim Level: SLT Laramie
Rep:74
Nck will become famous soon enough
Default Tire losing air---not sure where to ask this. so
One of my tires keeps losing air, and I've had it beaded, sealed, everything, but it still continues to lose air, it's a very slow leak though. Could this be a bad wheel maybe?
Old 01-18-2013, 09:53 AM
Rep:1845
Yes, it certainly could. Porosity can happen in wheels, as well as aluminum transmissions and transfer cases. The easiest way to find the leak is to submerge the wheel and tire in water and look for bubbles.
Old 01-20-2013, 11:48 AM
goodname4id's Avatar
goodname4id goodname4id is offline
Vehicle: 2006 Dodge Ram 2500 Quad SWB
Color: Maroon
goodname4id is on a distinguished road
Default soapy bubbles
If submerging the tire is not an option, try spraying the tire with a soap+water solution in a squirt bottle. (like an old glass cleaner bottle) I once found a hole in a tire 2 inches up the sidewall where an object had pierced the tire and pulled out leaving an almost undetectable leak far away from the tread surface.
first place I would spray would be the valve stem.
Old 01-20-2013, 04:56 PM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:108
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
I agree. I use dish soap and water works everytime. One quick way to check the valve stem is to simply spit on your finger and smear it on the valve stem and watch for bubbles. Yeah, gross maybe but it works.
Old 01-21-2013, 12:10 AM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Valve cores are also likely culprits. I have the same issue myself. My RR tire is slowly losing air I have to check that.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
