Old 01-18-2013, 07:03 PM
jrdn's Avatar
jrdn jrdn is offline
Vehicle: 1998 dodge ram 1500
Trim Level: Stock
Color: dark blue
jrdn is on a distinguished road
Default long crank to start and radical idle
I have just finished putting my motor back together and I started it up and it takes 2times to start and when it does the rpms go up and down and it sounds like it has a big cam and as soon as you push on the gas it acts like it floods out and dies. I have replaced the aic valve and the tps sensor but I dont have a second o2 sensor hooked up any idea what would cause this would be greatly appreciated thanks
Old 01-18-2013, 07:25 PM
Rep:1845
I would check fuel pressure for the starting problem and look for a vacuum leak for the idle problem.
Old 01-18-2013, 07:58 PM
jrdn's Avatar
Trim Level: Stock
Color: dark blue
Thanks for the info ill have to check that next time I have time to work on my truck. Would you know why it will start sputtering and wqnt to die as soon as I press on the gas?
