Old 01-19-2013, 03:23 PM
punisher69's Avatar
punisher69 punisher69 is offline
Vehicle: 2012 Ram
Trim Level: slt crewcab 4x4
punisher69 is on a distinguished road
Default 315/70/17 fit with 2" level?
I am probably going to swap my stock 20" alloys and tires and go down to a 17" wheel and tire combo seeing as i can do this for close to same price as just replacing the 20" tires to a bigger size.Also i think it would look better,a 315/70/17 tire compared to a 295/65/20. Down the road also the tires would be cheaper which is another bonus and hopefully i can sell my set for at least a grand as they only have about 11000 kms on them.So my question is,will these tires fit on a rim with 0 offset or would i need at least a -6 offset? Can the tpms from the 20" rims be used in the 17" rims as that would save some coin also. So will this combo fit on my 2012 with a 2"HBS level no problem or will there be some rubbage on the inner fender plastic? Any pix of your truck with this combo would be greatly appreciated,thx.
Old 01-19-2013, 11:49 PM
bdub1289 bdub1289 is offline
Vehicle: 2003 Dodge Ram 5.7 HEMI
Color: BLUE
bdub1289 is on a distinguished road
Put a leveling kit on mine and i fit 35x12.50x20 with room for more. Not sure if that helps any. Good luck.
Old 01-20-2013, 09:54 AM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
yes you will i did the same droped to 17's and that tire size,...i have a 2mm offset and theres the same gap maybe a little more than facotry on the inside.heres mine with 2.75 bilstiens
2011 Hemi RCSB Sport 4x4
Old 01-20-2013, 10:00 AM
dwanton's Avatar
dwanton dwanton is offline
Vehicle: 2013 power wagon 2500 loaded
Trim Level: crew cab loaded
Rep:80
dwanton will become famous soon enough
good information to know .
the larger the wheel size the higher the cost of the tire ?? so there is less tire and rubber to make it but it costs more ?
i was thinking of 18's if I go aftermarket but i do like the stock chrome 20's .
2013 power wagon 2500 - 5.7 everything but leather.
Old 01-20-2013, 12:16 PM
punisher69's Avatar
Vehicle: 2012 Ram
Truck looks great! So those tires on there are 315/70/17 ? What lift is on there,a 2.75 Bilstein or the 4"lift in your signature? You also say those rims are 2mm offset,is that +2 or -2,thx.
Old 01-21-2013, 06:14 AM
Vehicle: 2011 Ram
Rep:141
this pic is just the 2.75" bilstiens, yes its 315's and that is a +2 mm offset...no rub what so ever
Old 01-21-2013, 12:49 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
Looks great
I have 315/70/17's on my truck currently with stock "offroad" rims +19, I had to use a 1/4 spacer for it to not rub. So a rim with close to 0 offset or - offset will be good.
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 01-22-2013, 05:14 PM
punisher69's Avatar
Vehicle: 2012 Ram
Thx for the replies guys,so can the tpms be re-used from the 20" rims to the 17" rims?
Old 01-25-2013, 07:03 PM
Vehicle: 2011 Ram
Rep:141
no sure but almost any brand tpms will work with the ram
Old 02-26-2013, 03:07 PM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
I know this is an older thread but did you end up going with the 315/70/17’s? I’m looking to do the same thing this spring. Installing a leveling kit and dropping my stock 20’s for a set of 17” Dick Cepek DC2’s with a -13 offset wrapped in 315/70/17 BFG Allterrains… Just curious if it worked out for you.
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
