Old 01-19-2013, 07:00 PM
SCWJeremy SCWJeremy is offline
Vehicle: 2002 Dodge Ram 1500
SCWJeremy is on a distinguished road
Default Check Engine light out
I just bought a 2002 Ram 1500, when I tried to get the emission test they wouldn't test it because the "Check Engine" light does not work. I later found out that it has a p0443 code. I checked the fuses and they all seem fine. What else could cause the check engine light to go out?
Old 01-19-2013, 07:35 PM
Rep:2657
P0443 Evap Purge Solenoid Circuit
read this post, it has the same issue
http://www.ramforumz.com/showthread.php?t=97629
welcome to the Z for Rams
Old 01-30-2013, 01:23 PM
yeoldecycleshoppe yeoldecycleshoppe is offline
Vehicle: 2004 Dodge Ram
yeoldecycleshoppe is on a distinguished road
Not to be Captain Obvious here, but have you checked the bulb? When I bought mine there was no check engine light on, but my scanner showed 2 codes. The Check Engine bulb had been removed. I also had a Range Rover once upon a time whose CEL bulb had burned out because it was on all the time
Old 01-30-2013, 01:38 PM
Rep:1890
Agreed. Always start with the most obvious things first.
