Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 01-20-2013, 12:03 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Default Exhaust quick fix tips
Alright so in the process of hollowing out my cats i managed to bend or dis figure the driver side end of the y pipe. Where the y pipe meets the exhaust manifold. A small leak is now where those two merge together. Do you all have any tips for the fix besides removing the y pipe all over again?
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 01-20-2013, 11:43 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Sorry I dont have an answer for you however one of our talented members will be able to help you out.....Let us know how you make out.....
Old 01-20-2013, 12:10 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I am thinking your best bet would be to remove the ypipe and redo it
Old 01-28-2013, 12:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Can you explain more on what you mean? I find it hard to believe you bent the pipe to where it doesn't line up correctly.
When you tighten it to the manifolds work each side a little at a time.
Also, I hope you were careful with the guts of the cats, that stuff is incredibly bad for you. Should have been wearing a mask and gloves.
Sean
