Old 01-20-2013, 07:32 AM
HOOAHHemi's Avatar
HOOAHHemi HOOAHHemi is offline
Vehicle: 2006 Dodge Ram 1500
HOOAHHemi is on a distinguished road
Default Brake upgrade??
All this talk of lifting trucks and bigger wheel/tire combos has me thinking about upgrading the stock brake system. I have a 2006 1500 4x4 SLT. Anyone have any suggestions or set ups they could recommend for upgraded brakes? I wanna keep the factory rotor size so as to fit under a 17'' or 18'' wheel but the calipers, rotors, and pads I am looking to upgrade. Thanks for the help guys!
6'' BDS Suspension w/ Fox 2.0 rear shocks, Bilstein 5100 adjustable front struts, 17'' XD Addict wheels, 37x12.5R17 Mickey Thompson Deegan 38s, Diablosport inTune, K&N 77 Series intake, Flowmaster 10 Series SIDO, Mag-Hytec diff cover, Rumble Bee hood, one piece aluminum grill, Extang Trifecta.
Old 01-20-2013, 07:36 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
I'd like to do te same thing
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 01-20-2013, 08:49 AM
I push the skinny pedal
Rep:3277
I was very happy with the EBC sports rotors and greenstuff pads on the rear with greenstuff supremes on the front. I was running higher hp and a heavy set of 22s so stopping that rotating mass was a tall order on stock diameter rotors. Everything cost about $600 shipped from auto anything.
Kurtis
Old 01-20-2013, 08:57 AM
Rep:1877
Don't forget to add a set of braided steel lines to improve pedal feel and put a little more pressure to the calipers.
Old 01-20-2013, 12:46 PM
HOOAHHemi's Avatar
Thanks CdnoilRAM and Ramtech for the suggestions. My truck spent the first part of its life and the factory stuff is all ate up now. Def gonna need an upgrade when the lift and tires go on.
Old 11-21-2013, 06:33 PM
HOOAHHemi's Avatar
So I purchased a powerstop kit for front and rear including rotors and pads. I went to install the front rotors and pads today and couldn't get the caliper to fit back over the new parts. I'm almost positive that the caliper pistons were pushed back as far as they could go but still it wouldn't fit. It's about 5mm off. Any insight?? Thanks guys.
Old 11-21-2013, 09:35 PM
Rep:3277
Just to be the guy to ask the stupid questions first: you have the correct part numbers for your truck? You squeezed the old pads right against the inside of the caliper then replaced with new pads? If you're having trouble compressing the pistons you can pop the reservoir cap.
Kurtis
Old 12-31-2013, 06:59 PM
HOOAHHemi's Avatar
Just an update, I had the front wheels off today to replace the rusted/broken wheel studs (a separate issue) and I decided to give it another go with the brakes. I pushed the pistons all the way back into the calipers and everything fit perfectly. I only got the front brakes installed today as it was starting to snow and the sun was setting but so far I am pleased with how well they seem to be stopping. I did the break in for the pads and rotors and everything looks good so far. It is supposed to rain/snow in the new few days so we will see how they fair in the wet weather. Thanks again for the help.
Old 12-31-2013, 07:54 PM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
With my BDS lift I received SS extended brake lines. I never considered what RamTech suggests above as a possible reasoning for these new lines, beyond the obvious extension. Hmmmm.
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 01-28-2014, 05:34 PM
HOOAHHemi's Avatar
Ram357, let me tell you how much of a difference those SS lines make in the force it takes to push the calipers back in.
