Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 01-20-2013, 12:24 PM
jlewis480 jlewis480 is offline
Vehicle: 2003 Dodge Ram
jlewis480 is on a distinguished road
Default Brake bleeding - ABS
Is there a manual way to bleed the ABS system? I have bled the brakes and still seems to be air in the line and the brakes are not holding. 2003 Dodge ram 1500 5.7L 2WD. Please advise.
Old 01-20-2013, 12:34 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Sorry I dont have an answer for you however one of our talented members will be able to help you out.....Let us know how you make out.....
Old 01-20-2013, 01:21 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
the way i always do it is take the lid off of your brake fluid canister, open the bleeder on the passenger rear put a hose on it going to a bucket, get in the cab pump, pump, pump hold check to see if fluid is coming out, if not repeat untill it does, let it gravity flow for a minute or to, close the bleeder, move to the driver rear tire and repeat, then the front passeger tire, then the driver side, and then make sure your brake fluid level are correct this is just how i do it, it has worked for me on all my vehicles ive ever owned. Hope this helps, if there is a better way to do it hopefully someone will chime in
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 01-20-2013, 01:38 PM
Resident Technician
Rep:1915
You will need to run the bleed brakes function in the ABS module in order to remove any trapped air. This will require bleeding the brakes, running the function via scan tool and bleeding the brakes again.
Old 01-20-2013, 03:24 PM
I'm wondering if I just have a bad master cylinder and not the abs at all. I bleed the brakes as described one wheel at a time and all air is out. I drive the vehicle around and making frequent stops periodically the pedal will travel to the floor and feel spongy... Most of the time it would travel to the floor as I'm descending down hill. I don't travel away from the house to far.. Don't want to danger anyone else or myself. I guess I will bleed the brakes once more and if that fails I will go pickup a master cylinder and install it.
Old 01-20-2013, 03:31 PM
Resident Technician
Rep:1915
You should check for leaking calipers and wheel cylinders before randomly throwing parts at the truck. A line lock test will verify a master cylinder problem.
Old 01-20-2013, 03:51 PM
Thanks for the advice, Not one for just throwing parts at the truck without justification however could you give a little more detail on this line lock test. Would like to continue with my DIY but want to remain safe at the same time. Thanks in advance for your response.
Old 01-20-2013, 08:19 PM
Resident Technician
Rep:1915
You need 3 pairs of locking pliers and an assistant to do a line lock test. Clamp off each rubber brake line near the top (2 front, 1 rear). Press the brake pedal forcefully. If the pedal bleeds down, you have a bad master cylinder. If not, it's good. Now, have your helper release the pliers one by one with you pressing on the brake. You should notice only a mimimal drop in the pedal as each pair is released. Any big drops mean you have air in that particular section of the braking system.
Old 01-20-2013, 10:04 PM
Rep:3337
Now that's something I didn't know. Awesome info Randy.
Old 01-21-2013, 09:56 AM
Wow,
Great explanation.. Thanks will do it exactly as described and get back with you about my findings. Is there a similar test for the power booster or will this test take care of them both.
