Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
United Radio
Old 01-21-2013, 10:05 AM
Rep:1845
The booster pretty much works or it doesn't. Symptoms for a bad booster are a hissing noise under the dash that indicates a faulty diaphragm and a high, hard brake pedal due to a lack of assist from the booster. A faulty booster will not cause the brake pedal to bleed down.
Old 06-15-2014, 11:14 AM
my87csx481 my87csx481 is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT regular cab
my87csx481 is on a distinguished road
Originally Posted by RamTech View Post
You will need to run the bleed brakes function in the ABS module in order to remove any trapped air. This will require bleeding the brakes, running the function via scan tool and bleeding the brakes again.
Anyone know if there is an affordable aftermarket scan tool that will run this function? If so, which one or ones?
Thanks in advance for any help.
