Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
tonneaucovered.com
Old 01-21-2013, 12:57 AM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
Yup.. I never ran oiled filters. Also those turbos suck a lot of air... which can suck oil up into the turbo... I only run dry. I ordered mine from
http://www.xtremediesel.com/afeprodr...m51-31342.aspx
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 01-21-2013, 01:16 AM
kozzy kozzy is offline
Vehicle: 2016 Ram 3500 Big Horn
Color: Delmonico Red
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
kozzy is on a distinguished road
Thanks again. The actual part number I need for mine is slightly different, and on that site it is 447... I just found it on realtruck.com for355 and free shipping, I think I'm gonna go with it. Thanks again for all the info
Old 01-21-2013, 01:21 AM
https://www.xtremediesel.com/afestag...r51-12032.aspx
Check this out, seems to be the one I need....
Old 01-21-2013, 01:28 AM
Ram725's Avatar
Rep:347
If thats the one that fits then do it! AFE stage 2 pro dry S! Cant go wrong. Only other intake I would even consider is S&B. But like I said all I ran on my diesels was AFE. I just now am running S&B on my Hemi. I just know they are both good products so I would go on which one is the best $$$. But those are the only two CAIs I would run on a Cummins
Build Thread
Old 01-21-2013, 01:08 PM
RugbyRef's Avatar
RugbyRef RugbyRef is offline
Vehicle: 2012 Dodge Ram 2500 (CTD)
RugbyRef is on a distinguished road
For the Cummins my personal favorite is AFE Stage 2 Pro Dry S. I also love S&B. I ran AFE on all my Cummins and most guys at the strip and tractor pull use AFE. IMO just always run Dry. JMO.
The 6.7 does have a better intake than the stock 5.9, but I have always thought that CAI's are almost necessary on Cummins... But this is JMO
This is exactly the same CAI I put in my truck. I went ahead and did it for the simple reason that I also did the DPF delete and EGR removal and installed an H&S Mini Maxx, so I figured...what the heck? I went with AFE for their reputation with Cummins.
Tim
Old 01-21-2013, 01:16 PM
I ordered mine last night, Now the DPF and EGR delete, what does that involve?
I was also looking at the H & S Mini Maxx, what does that cost, and what is involved with using that? I am not tne to cars and mechanics, but I am new to doing these types of mods. Im happy with the power I have, I would like some better MPG's though.
Old 01-21-2013, 01:32 PM
RugbyRef's Avatar
Kozzy:
The DPF delete I had completed by a local shop who has better tools than I do for removing the exhaust back to the turbo and installing a custom exhaust. The EGR removal I did myself, and, although it took me all day, was pretty simple to do.
I ordered my EGR removal kit from Custom Diesel in Morristown, TN. They send you install instructions with it, but to be honest they are not accurate. I had to update the instructions for a 2012 6.7L Cummins. The best kit (install instruction-wise) I think (if you can find one) is made by H&S. They are based out of Utah. Unfortunately, they have temporarily suspended their operations somewhat due to a riff with the EPA. Not sure when that will be resolved.
I also found and purchased an H&S Mini Maxx tuner (with pyro and OD software) and installed that as well. All told it cost me a couple grand for all of the mods. Again...I did a lot of the work myself, so that shaved off some labor cost.
It is all well worth it though! I am seeing incredible HP gains and much improved gas mileage. If you want to get more info, other than what you find in this forum, I would recommend checking out a few of the forums that specialize in diesel performance.
Hope this helps!
Tim
Old 01-21-2013, 01:42 PM
Designflaw's Avatar
Designflaw Designflaw is offline
Vehicle: 2013 Ram 1500 4x4 Sport
Rep:40
Designflaw is on a distinguished road
I never liked banks and neither did the other guys with Cummins that I ran with. Personally I think AFE Stage 2 pro dry S is the best for the Cummins... Thats just my opinion.
I Agree - From my 2500
2013 CC Sport 4x4: 3.55, 20% Tint, Line-X, fender flares, mud flaps, Weather Techs, bed cover, 2.5 Leveling kit, Blacked out emblems, Vararam Air Grabber
2008 M109R LE, 1999 TL1000R, 2003 Yamaha Golf Cart :hah:
Old 01-21-2013, 01:53 PM
Ram725's Avatar
Rep:347
Removing the DPF and EGR is one of the most important and wise investments you can make with a 6.7L. Problem, some states will not let you due to vehicle inspections and it voids all and any warranties. However if your state allows and you could are less about warranties DO IT. right now your air flow is like a straw. Removing DPF and EGR will let the motor breath. It makes the motor more bulletproof, massive increases in HP, and massive mpg increases. When you delete the DPF and EGR you have to get a programmer like H&S to remove engine codes. Otherwise your engine will throw a code. This is probably one of the most important mods and wisest investments you can make. But it is pricey and will remove warranties. IMO, it is 100% worth it.
Build Thread
Old 01-21-2013, 05:30 PM
skinnysfd's Avatar
skinnysfd skinnysfd is offline
Vehicle: 2012 dodge ram 2500
Trim Level: big horn
Rep:53
skinnysfd will become famous soon enough
as stated above you can all of it yourself even the exhaust is fairly easy . Alot of your diesel shops will sell what they call the complete dpf,egr,programmer kit usually and it includes it all. I always got my parts from either kens performance solutions or alligator performance, or throughbred diesel. Great guys to work with and very fair priced. just did a buddies truck with him and for everything i believe it was right around $1400-$1600 for all parts and a afternoon of working and some beers and his truck was done and on the road. Best investement ever on these new diesel is getting rid of the emissions crap. Also depends on your dealership because some of them will let you do the deletes and still warrenty it. I know m dealership will honor warrenty even with the deletes. Might want to check into that first, but sometimes takeing the risk is worth it to because we have had to put the exhaust and dpf back on before for a guy so he could get his dealership to warrenty it.
2012 RAM 2500 HEMI AFE CAI flowmaster dual exhaust,airlift 5000 bags w/onboard compressor,shaved tailgate,2.5" lift/level tuftruck front springs,bushwacker pocket flares,gear alloy wheels, goodyear duratracs 315/70/17,bd gt hemiplus tuner much more coming
04.5,2006 5.9l cummins
