Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 01-20-2013, 12:31 PM
burny30 burny30 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: Regular Cab Sport
burny30 is on a distinguished road
Default 98 Ram Transfer Case won't stay in 4WD
98 Dodge Ram 1500 won’t stay in 4WD.
I adjusted the linkage to make sure its going all the way "home". I got under the truck made sure the front drive shaft was locked in. I got on some ice and applied power the front and read wheels pull for while and then the transfer case disengages. The linkage doesn't move, it stays "home" but its no longer engaged. I cycle the shift lever back to 2WD and then pull it hard back to 4WH. It engages again, but as soon as I apply power it pops out.
Has anyone been inside one of these case and know what could be happening? I could just et a $500 case from a bone yard. But I hate to do that if it could be a $200 part inside.
Any help is appreciated.
Thanks.
Old 01-24-2013, 09:50 AM
wessendorf15 wessendorf15 is offline
Vehicle: 1997 dodge ram 1500 4x4
Trim Level: laramie
wessendorf15 is on a distinguished road
your gaskets and bearings are bad. go to advanced auto parts and get t case rebuild kit. only like 200$ first find out what kind of t case you have.
Old 01-28-2013, 10:22 AM
Trim Level: laramie
what happens is ur bearings allow ur t case to transfer and turn ur axles. when they go bad it cant handle the horsepower cause they get worn out and allow space between em. inreturn cause it to slip and not transfer over when u push down on the pedal.
