Old 01-20-2013, 02:44 PM
Yo Nadz Yo Nadz is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Trim Level: Sport Crew Cab
Color: Snow White
Rep:160
Yo Nadz has a spectacular aura aboutYo Nadz has a spectacular aura about
Arrow 2013 Ram HID Conversion Thread...
I know I'm interested in doing this, as I'm sure others are. Those who have converted headlights and or fogs to HIDs PLEASE POST UP!! Include brand, voltage, pictures and any other information you deem appropriate. Discuss....
Yo Nadz STOMPER Build Thread ~> http://www.ramforumz.com/showthread.php?t=135821
Lifted & Ignorant 2013 Sport Crew
Proud member of IAFF LOCAL 2665
Old 01-20-2013, 06:40 PM
Asur Asur is offline
Vehicle: .
Rep:4373
There is already a thread on this
http://www.ramforumz.com/showthread.php?t=129732
If you do a search using the Search button up on top you will find this stuff
Old 01-20-2013, 06:43 PM
s1000rrhp s1000rrhp is offline
Vehicle: 2013 Dodge Ram
Rep:13
s1000rrhp is on a distinguished road
Have some hi beam and low beam pics...
I used a Hi end plug and play kit called CAN-BUS they us all philips components. I tried a less expensive one on the fogs, however it didn't work. 2012 you could get away with it however this year Ram upgraded the wiring and it now requires a high end kits to stop flickering. I used 35w kits don't want to risk using 55w not worth the hassel and its a pain to keep changing bulbs in the ram truck. I have 10000k in the projectors right now as they were out of 8000's. will be putting in 8's in a couple of days. I like having a bit of blue with the white truck
they are 9006 bulbs in the projector and fogs and 9005 in the high beam "i think "
Old 01-20-2013, 08:38 PM
Color: Snow White
Rep:160
Do you have any pics of the install? Was there a good place to mount the ballasts? Did you have to modify the housings at all?
Old 01-20-2013, 10:10 PM
Rep:13
u can mount the ballasts on the frame right behind the headlight assembly.. take the grill off, then the headlights. their is a plastic clamp you need to pull down behing the headlight assembly to get them out. Go to the body shop and get some good quality adhesive 2 sided tap to mount the ballasts on the frame its good up to 25lbs so they wont fall off trust me. That way your not screwing 6 ballasts into the frame. Use a heat gun to warm the frame and the tap also clean frame with some adhesive bonding alcohol.You will need to drill out the plastic behind the headlight assembly to run the new harness through it. most of them come with a grommet. Sorry no pics of install
Old 01-21-2013, 08:57 PM
Rep:13
here is a link for install
http://gtrlighting.com/forum/index.p....msg134#msg134
Old 04-02-2013, 06:52 PM
jcbowen's Avatar
jcbowen jcbowen is offline
Vehicle: 2013 RAM 1500 sport
Rep:13
jcbowen is on a distinguished road
Where did you buy these from?
Old 12-27-2013, 06:30 PM
JCMeza1982 JCMeza1982 is offline
Vehicle: 2013 RAM 1500 Sport 4x4
Color: Mineral gray
JCMeza1982 is on a distinguished road
Cool hid kit brand cost etc..
As the previous user asked, where did you buy them from?
I tried the kits from DDM tuning and they didn't work at all. It would flicker then turn off.
Old 12-28-2013, 05:37 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
The Custom Dodge Ram Interior and Exterior Lighting
Lots of light options are found here and also how to install. You can also use the search link.
http://www.ramforumz.com/forumdisplay.php?f=78
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 04-25-2014, 02:20 PM
atink33 atink33 is offline
Vehicle: 2013 Ram 1500 sport
Trim Level: wicked
atink33 is on a distinguished road
Hey man,
That looks really sharp. I have the same truck and was hoping to do the same thing. Have you had any issues since installing these? Would you mind sending me the website for where you purchased the kit from? Thanks!
