Old 01-27-2013, 12:15 PM
s1000rrhp s1000rrhp is offline
Vehicle: 2013 Dodge Ram
Rep:13
s1000rrhp is on a distinguished road
Looking at the set of '13 projectors that I have, the route of entry that I see is the lower vent. I would try silicone on the lower vent to seal it off and keep the upper vent open. Then heat the entire assembly to vaporize and expel any moisture. This should stop moisture intrusion and allow any build up to vent out the top.
I thought about doing this... however if i mess up the design worse then i am really screwed. Winter will be over soon then condensation should go away
Old 01-27-2013, 12:56 PM
Asur Asur is offline
Vehicle: .
Rep:4371
My Question is why something as simple as the Front headlamp unit just not being sealed, seriously, what will it look like after spending 5 years running around the construction site on gravel and dirt and sand or just plain road dust???? often you will see headlamp off other vehicles that are supposed to be sealed full of crud, what will it look like when you been driving it that long on dry dirt roads and then get condensation from a cold night, next day hot and dry fields of dust????? I wanted these for my truck, think I will wait and see what happens with these.
Old 01-28-2013, 10:59 PM
Rep:13
well if i had the power to get chrysler to recall this problem i would.... however at this point looks like aftermarkets down the road will be in the books. If it is an issue will be the last chrysler i buy. Never had an issue till i bought a 2013, this is my 7th truck and may be my last.
Old 01-29-2013, 12:21 AM
I push the skinny pedal
Rep:3277
If it's that much of an issue, I will trade you my quad headlights for your projectors.
Kurtis
Old 01-29-2013, 01:58 AM
2013Sport's Avatar
2013Sport 2013Sport is offline
Rep:20
2013Sport is on a distinguished road
I noticed a little condensation on the led part of the headlight... I'll have to check to see if it's in the hi-low beam section tomorrow.
Old 01-29-2013, 02:42 PM
HorseMan's Avatar
HorseMan HorseMan is offline
Vehicle: 2014 6.4 Hemi; traded 2013 CTD
Trim Level: Laramie Crew 4x4
Rep:139
I checked several on the local lot here and didn't notice any condensation. We've had some significant temperature changes of late-maybe they fixed the problem along the way. Dealer here is getting quite a few in with LED's all around.
2014 2500 Laramie Crew 6.4 Hemi, 4.10 axle
2013 RAM 2500 Laramie Longhorn, Cummins, Western Brown (traded)
Old 01-29-2013, 06:51 PM
2013Sport's Avatar
Rep:20
Well after inspecting the headlights, I found there's only a little condensation on the led part. Hi-low beam section are fine.
Old 01-29-2013, 08:38 PM
Rep:13
You tell me if this is not a problem......
look at pics...... It does only happen in the cold
Old 01-29-2013, 08:45 PM
Vehicle: .
Rep:4371
I think your head lights have a problem, there's like snow in them LOL
Just kidding, but seriously that sucks.
Old 01-31-2013, 12:11 PM
Rocky Harbour Rocky Harbour is offline
Vehicle: 2010 Dodge 1500 Ram - Quad Cab
Trim Level: TRX 4 Off Road
Color: Brilliant Black Crystal Pearl / Light Greystone Pearl
Rep:26
Rocky Harbour is on a distinguished road
That definitely does not look right.
There is no doubt that part of the problem could be that LED lights don't produce the same heat as a standard bulb. I have heard issues especially with LED tail lights becoming completely covered in snow when you are driving. A standard bulb will produce enough heat to keep some of the snow melted off of the lens.
I would not be a happy camper for sure!
