Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-21-2013, 01:30 PM
bdodge445 bdodge445 is offline
Vehicle: 1995 Dodge Ram
Trim Level: Laramie SLT
Color: Black/Gray
bdodge445 is on a distinguished road
Default A NEW heat problem seriously this has got me stumped
1995 dodge ram 1500 5.9 Typical low-no heat as is common, but with a twist. I just put in a rebuilt engine in my truck, bad rod bearing Anyway so obviously I would replace a few things during the install, plenum gasket fix, bypass hose, water pump, t-stat, and heater lines. I figured this would cure my no heat issue. It did not. I then tried flushing the heater core, nothing impressive came out and both hoses were hot to touch. I replaced the heater core anyway because I could smell a slight antifreeze leak. While the dash was tore apart I verified proper function of the blend door, which is cable operated on my truck and it functions as it should. So to sum it up I have replaced the following: t-stat, all hoses, water pump, heater core, verified function of blend door. And still no heat. What do you guys/gals think? I'm lost....
Old 01-21-2013, 05:31 PM
Rep:1877
When you say no heat are we talking ice cold or just lukewarm like you may be getting some heat but not nearly enough?
