ZDOG
Old 01-21-2013, 01:56 PM
Jim D Jim D is offline
Vehicle: 2012 Dodge Ram
Color: Gray
Jim D is on a distinguished road
Default Dodge Ram 2012 Towing
Any suggestion on actual towing capacity ie actual weigh? Looking to tow a fifth wheel. 5.7 hemi crew cab
Old 01-21-2013, 06:46 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Generally towing a 5th wheel with a half ton is not a good idea and without knowing the gross vehicle weight rating (GVWR)of the trailer (do not confuse with dry weight) it is impossible to know for sure. There are small 5th wheels, so it may be possible. The problem with 5th wheels and towing with a half ton, is the pin weight of 5th wheels is approximately 20% of the GVWR which can easily exceed the capacity of a half ton.
Old 01-21-2013, 09:02 PM
KYSEAN's Avatar
KYSEAN KYSEAN is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express Crew Cab
Rep:21
KYSEAN is on a distinguished road
I'm sure some people do but I wouldn't even consider it.
Trailer Hitch, Line-X Spray In bed liner, S&B CAI, Magnaflow 22" and Y-Pipe, ARE Hard Tonneau Cover
Old 01-21-2013, 09:44 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
I don't think a fifth wheel is a good idea with a 1/2 tonne pickup. It's not pulling the weight of the trailer it's the payload capacity of the truck. Even the light ones push the payload capacity of a 1/2 tonne.
Once you add supplies in the trailer, gas in the truck and passengers it will almost certainly be over.You also need to add the weight of the hitch; since you have a CC you'll need a sliding hitch and that adds to the weight as well.
Old 01-22-2013, 12:44 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Bad idea. The whole idea of getting a nice 5th wheel is too get a nice BIG one. Get a pull behind travel trailer and you and your truck will be much happier. I've read guys that have done the 1/2 ton 5th wheel route and moved up the a 3/4 or 1 ton. They said they would never do that again ( use a 1/2 ton for a 5th wheel).
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 01-22-2013, 03:13 AM
Rep:2720
I wouldn't use a 5th wheel on a 1500
i can see it now, going to the dealership with broken parts, 5th wheel setup in the bed
they would say, WHAT WARRANTY, are you kidding ?
Old 01-26-2013, 12:59 PM
Hardware's Avatar
Hardware Hardware is offline
Trim Level: Outdoorsman
Color: Black over Grey
Rep:31
Have you seen this 5th-wheel thread?
