Old 01-21-2013, 03:34 PM
KMoor91 KMoor91 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Lamarie
KMoor91 is on a distinguished road
Default Trans cooler help
Does the 201 dodge 1500 with 5.9 come with aux coolers?
Old 01-21-2013, 04:54 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
I believe if you have the trailer tow package it comes included. If you want to be sure just look for a small radiator around the area of the grille.
Old 01-21-2013, 05:10 PM
Trim Level: Lamarie
Ok is it the one behind the ac cooler? And how should the transmission lines be hooked up? Bc I got a hose just danglin off the bottom of the radiator... With the aux cooler should the radiator be bypassed
Old 01-21-2013, 05:22 PM
ramvan2500's Avatar
Rep:128
I think it is the one behind the A/C cooler, if your vehicle has a power steering cooler then that would be located next to the engine radiator.
Usually the correct setup for a transmission cooler is, transmission pressure line -> anti-drain back valve-> engine radiator cooler-> external cooler-> transmission return.
I don't set it up like this, I setup mine like: trans pressure-> external cooler->eng rad cooler->transmission return.
I setup mine like this because it allows me to remove the anti-drain back valve and still retain the feature of anti-drain back by mounting the external cooler higher than the centerline of the torque converter. But it also allows me to pre-cool the transmission fluid before entering the engines radiator, this ways I don't heat up the engine coolant as much. If you choose to go stock setup, if you actually are under enough of a load the transmission fluid would be able to heat up the engine coolant enough to cause the engine to actually over heat. Happened to me. Oh nascar also uses this setup.
Old 01-21-2013, 05:29 PM
Trim Level: Lamarie
So transmission cooler lines should be hooked up to passenger side of radiator?
Old 01-21-2013, 05:56 PM
ramvan2500's Avatar
Rep:128
Yup, one should go into the passenger side then come out at the driver side, in the stock setup you would slap the external cooler between the output of the radiator at the drive side and the return on the transmission.
