Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-21-2013, 05:46 PM
jakemon jakemon is offline
Vehicle: 1999 Dodge Ram 1500
Color: red
jakemon is on a distinguished road
Default 1999 Ram 1500 no heat
Hello I have a Dodge Ram 1500 V8 Laramie style. Driving today with very little heat. Engine running cold on the highway (180 degrees - usually runs around 205). Checked coolant - ok. Upper rad hose hot, lower rad hose ice cold.
stuck thermo ?
plugged up heater core ?
any other ideas ?
Old 01-21-2013, 05:49 PM
Rep:1890
Possible causes are: Low coolant level, stuck open thermostat, poor coolant flow, blend door problem, or the heater core. The most likely cause based on your description of the symptoms is a stuck open thermostat.
Old 01-21-2013, 07:43 PM
Color: red
Thanx for the reply ! Appreciate your speediness.
