crazy heat problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-21-2013, 07:20 PM
chief4101 chief4101 is offline
Vehicle: 1994 ram
Trim Level: base
Color: red
chief4101 is on a distinguished road
Default crazy heat problem
i recently bought a 94 ram half ton with a v6. the heater blows cold to slightly warm air at best. it has a newer water pump and rad. i replaced that t stat with a 195 unit. when that truck is warm the gauge reads just above 200, the top hose and both heater hoses feel warm and all about the same temp but the lower hose stays cool to touch, i removed tha new rad cap and the antifreez is cool enough i can put my finger in it with no discomfort. im not real up on dodge as it is the first one i have owned in 20 years.
any ideas?
Old 01-22-2013, 09:02 AM
Resident Technician
Rep:1915
That problem has heater core written all over it.
Old 01-26-2013, 01:11 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
It could be a slightly clogged heater core, its fairly easy to unclog it. It could also be the vacuum actuate flap that controls the temp from the heater core. You can use that radiator flush they sell at the auto parts store to clear up the heater core or stick a flexible rod through the core. Flush it out with water afterwards.
