Old 01-21-2013, 06:43 PM
BAMA98 BAMA98 is offline
Vehicle: 1998 Dodge Ram
Color: Flat Tan
BAMA98 is on a distinguished road
Default wont crank on first try
Bought a 98 ram. 84k original miles. Its an awesome toy. Only issue is it wont crank up on its first try. It takes 2-3 trys before it'll turn over. I put new plugs/wires/battery/alt/air filter/ ran gas treatment... basically a full tune up. And its still having this issue? Any ideas?
Old 01-21-2013, 07:10 PM
Rep:1885
Won't crank or cranks but won't start?
Old 01-21-2013, 07:52 PM
Color: Flat Tan
sorry, it'll crank.. just wont turn over on the first start. It takes 2-3 tries before it'll turn over.
Old 01-22-2013, 08:11 AM
Rep:1885
I would hook up a fuel pressure gauge, turn the key to the run position but do not crank the engine. If you have less than about 50 psi of fuel pressure, then chances are that the check valve in the pump unit is bad and fuel is draining back into the tank when the pump stops running. The pump unit will need to be replaced to maintain volume in the lines.
Old 01-26-2013, 10:13 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
If on first try you mean it does not roll the engine over it could be the contacts inside the starter solinoid. $20 and a little labour and it would be back to like new. Very common problem on Ma's starters. This applies to old full size and the newer style mini starters.
Old 01-29-2013, 02:27 PM
Color: Flat Tan
now it wont fully crank.. i can get it to turn over if i keep giving it gas. But asoon as i stop giving it gas it just dies.
