Old 01-21-2013, 08:36 PM
woodtoolguy woodtoolguy is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: SLT Reg Cab, 8' Box
Color: Deepwater Blue Pearl
Rep:48
woodtoolguy is on a distinguished road
Default Front Diff Mod - MEH Outcome
I bought the Mag-Hytec Diff cover for the rear axle, but was disappointed I couldn't find one for the front.
I like the extra capacity and magnetic drain plug features, so I decided to modify my stock front diff with a drain to make it easier to service.
After driving the truck onto the ramps, I removed the front diff cover. Here's a shot of the parts used. Diff cover, 1/2" X 3/8" NPT reducing bushing, 3/8" NPT plug. Ignore the magnet, I could not attach it to the plug reliably:
Here's the oxy-acetylene torch & Dremel tool used to make the hole for the drain:
The raw hole, painted silver to show the details better:
Dry fitting the drain, viewed from the inside:
Dry-fitting, viewed from the outside:
Welding tools:
Welded, painted & curing in the parts oven (an old Weber grill):
Yeah my welds stink, but I'm getting better!
Here's the final install, after refill and test drive - NO LEAKS!!!
Still have to drop the front skidplate to change the fluid, but no more messy gear oil spills. I'm looking into a magnetic drain plug to install at the next gear oil change.
I like the function and the drain is low on the cover to fully drain the fluid. However, the plumbing fittings look out-of-place on the stamped steel diff cover. In retrospect, machine fittings would look better.
Also, I gotta weld A LOT MORE to improve technique & outcome.
Thanks for looking.
woodtoolguy
Old 01-22-2013, 08:22 AM
Clifford17 Clifford17 is offline
Vehicle: 2012 Dodge Ram
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
Looks like a good mod...
Old 01-23-2013, 01:41 AM
storeboy storeboy is offline
Vehicle: 2009 Dodge Ram
Rep:19
storeboy is on a distinguished road
I likey!
I have no welding skills so all I can do is look and admire from afar. I have siphoned mine out with a little hand held pump and didn't make any messes. With the amount of new fluid I put back in, I must have got it all.
Old 01-23-2013, 07:04 PM
JFM-jr JFM-jr is offline
Vehicle: 2009 Dodge Ram 2500
JFM-jr is on a distinguished road
Did you look into PML?
http://www.yourcovers.com/diffcover_11046.php
Old 01-25-2013, 07:31 PM
Rep:48
Originally Posted by JFM-jr View Post
Yeah, I checked PML a few weeks ago, but they didn't have that front diff cover listed. Not sure I would pay that much for a new cover with a drain & .25 qt extra capacity.
I spent about $10 in pipe fittings for nearly the same results, plus I gained welding experience.
I was able to find a 3/8" NPT magnetic drain plug for $3 at McMaster-Carr. That's going in at the next gear oil change.
Thanks for the info.
woodtoolguy
