Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 01-22-2013, 09:13 AM
scuba0331's Avatar
scuba0331 scuba0331 is offline
Vehicle: 2014 Ram 3500 CTD Crew Cab
Trim Level: Bighorn
Color: Deep Cherry Red
Rep:20
scuba0331 is on a distinguished road
Default Fittings
Well I installed the TLC suspension kit. So far both of the Schrader valves I have leak and one of the Y fittings leak as well.
Anybody know of some better fittings I can purchase? Hopefully, I can find some Parker Hannfin or Swagelok fittings that will work. I may end up going with compression fittings that use a ferrule.
I have 2 full days into the installation only to have leaks is not fun. Especially since my schrader valve is part of my Radio Console now.
[SIGPIC][/SIGPIC]
