E-Brake cable hanging loose - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-22-2013, 09:00 PM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
Default E-Brake cable hanging loose
Yesterday, my buddy was parked beside me as we were about to leave. I went to release my e-brake and be suddenly yelled for me to stop. When I released my e-brake, he instantly seen a cable hang down under the truck.
It's definitely the e-brake cable, it doesn't retract in, when you apply the e brake it's fine and has tension. When released it hangs down pretty low with a ton of slack
Been a ton of salt on the roads, could that be causing something to seize and not allow the cable to retract?
I still have bumper to bumper and was going to take it in to get checked out. The e-brake still works fine, just concerned its not properly releasing
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 01-23-2013, 11:17 AM
cwsomerton cwsomerton is offline
Trim Level: TRX4 Off Road
Color: Black/Grey
cwsomerton is on a distinguished road
Had the same issue last year turned out to be broken e brake levers. Ended up replacing e brake shoes, rear rotors, and the levers under warranty. Pads were not covered but were fine anyways. They told me they were worn out, I have since put 30,000 kms on them and they still aren't worn out. Another dealer money grab so beware!
Old 01-23-2013, 11:28 AM
Rep:156
Awesome, thank you! Goes in pretty soon to get looked at. I had an inspection done not long ago and they said my brakes had a ton of life left so I'm not too worried about that part
Old 11-30-2014, 07:26 PM
misfit1981's Avatar
misfit1981 misfit1981 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4x4
Color: Silver PS2
Rep:45
misfit1981 is on a distinguished road
Default E-Brake Cable Drooping
So you're saying it's the lever I'd press with my foot to engage the e-brake went bad? My cable is drooping low 4" below the frame. The dealership said it was normal. BS
"To be prepared for war is one of the most effective means of preserving peace." -George Washington
Old 06-13-2017, 12:57 PM
marathonsp10 marathonsp10 is offline
Vehicle: 2014 ram crew cab express
Trim Level: Express Crew Cab
marathonsp10 is on a distinguished road
i have this problem on a 2014, it is getting looked at next week. will post an update on the solution from the dealer. i have a max life warranty
Old 06-14-2017, 09:31 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
Subbed...
Old 07-03-2017, 08:24 AM
Update, truck went in for regular maintenance, gave them the complaint that the parking brake cable was hanging low, and that i looked under the truck and the parking brake seemed to be somewhat engaged. They put a whole new parking brake assembly in the truck covered under warranty. i have the max life warranty but the truck only has 30k miles on it.
