Old 02-05-2013, 08:53 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
Let me know how its going, if you need any other help pm me over at GPMM. Good luck!
Old 02-21-2013, 09:12 PM
oreo oreo is offline
Vehicle: 1998
Rep:41
oreo is on a distinguished road
Send a message via Yahoo to oreo
just a little update. Think my vacuum leak is behind my dash. Heard something strange like a high pitch sucking noise a couple of times when letting off the gas and it sounds like its behind the dash. anyone got a vacuum diagram for behind the dash or under it? or maybe any ideas what line could be leaking?
Jake
98 Ram QC 4x4 - www.gpmm.org
Old 03-12-2013, 02:55 AM
Camoray Camoray is offline
Vehicle: 2000 Dodge Ram 1500 Quad Cab
Trim Level: Laramie SLT
Color: Dark Blue Metallic
Camoray is on a distinguished road
I had almost the same problem with my 2000 Ram 1500 w/5.2 X 2WD....
usually after warm up it would stall at idle and immediately after shifting
into reverse......keep the idle up over 700 and no problem......I spent a lot of time doing what everyone said to do above but finally found it was the crankshaft sensor.....$50 part but a pain to install.....trucks running great.
Old 04-01-2013, 04:23 PM
Vehicle: 1998
Rep:41
think thats my next part to replace. since fixxing the vacuum leak or bypassing it for a while. the truck started another problem of not being able stay running on first start up after sitting for a while unless i keep my foot on the gas.
Jake
Old 04-20-2013, 12:20 PM
HemiJack's Avatar
HemiJack HemiJack is offline
Vehicle: 2008 Dodge Ram QC
Color: Sunburst Orange
HemiJack is on a distinguished road
What's the latest update on fixing the problem? Did the crankshaft sensor replacement work? Did you find anything else that might have been the problem?
Glenpool, Oklahoma......."The Little Town That Made Tulsa Famous"
Old 04-28-2013, 01:05 PM
Vehicle: 1998
Rep:41
Crank sensor and coil did not solve problem. Now its a cold weather problem at least so far. replaced throttle position sensor. guess we will see what happens.........
Jake
Old 05-04-2013, 10:53 AM
Vehicle: 1998
Rep:41
well the problem is still there...........but now that the weather is going to finally start getting warmer I may have to wait till fall to keep trying on the problem.
Jake
Old 08-19-2013, 11:08 AM
Vehicle: 1998
Rep:41
new problem has now come up. While at highway speeds the truck Jerks only once like hitting a speedbump at 65 mph. Then its good after that. it does it at random too, some days it wont do it and others it will. and no check engine light to be seen.
Jake
Old 10-18-2013, 12:35 PM
Vehicle: 1998
Rep:41
Well a little update. Replaced IAC, Crank position sensor, coil, ignition pickup, tps, and cleaned the throttle body, and the truck still does a big jerk like I hit something, just once or twice then it's good. Now when I start it it dies and I have to keep my foot on the gas to keep it running. Once it worms up it's ok, kinda. At idle it jumps about 200-300 rims and the lights flicker any ideas?
Jake
Old 10-21-2013, 07:38 PM
Vehicle: 1998
Rep:41
Update: now the truck dies after it idles up every morning and dies unless I keep my foot on the gas when braking until it warms up. Think this thing is going down hill fast
Jake
