Old 01-23-2013, 12:45 AM
Wickedwelder's Avatar
Wickedwelder Wickedwelder is offline
Vehicle: 1999 Sport 4x4
Color: Green
Wickedwelder is on a distinguished road
Question Instrument cluster help
What would cause my entire instrument cluster to quit working? Right now I have no gauges that work and when I first start it the odometer will flash the mileage about 3 times and then it just says "no bus". I've checked all the fuses in the cab and under the hood and they are all good. I have no idea what to check next. Anyone ever had this happen or have any ideas?
Thanks in advance for any help
Gary
"Courage is being scared to death but saddling up anyway" John Wayne
Old 01-23-2013, 11:00 AM
Rep:1885
Could be a bad cluster, a problem with the wiring, or even a ABS module issue. The no bus message means the data bus is inoperative and you will likely need professional help to diagnose the problem. Checking the fuses is a start. Did you check to see if there is actually power across them or just to see if they were blown?
Old 01-23-2013, 11:26 AM
Color: Green
I just checked to see if the fuses where blown. I'll check power across them this weekend.
Everything was working back in June when I took it to a trans shop. Don't know what they did but they couldn't get it started for a week, they ended up swapping out the PCM with one from the wrecking yard. After that it started right up, but my gauges haven't worked since. Just about all the warning lights are lit up on it also(abs,check engine,seat belt, emergency brake, and fuel light)
I was told at one time that I needed to get the PCM flashed, but not sure what that entails.
Old 01-23-2013, 11:46 AM
Rep:1885
Trans was out, huh? That makes me wonder if any wiring got pinched, the crank sensor in particular.
Old 01-23-2013, 01:45 PM
Color: Green
Trans wasn't out, they replaced two of the shift selonoids and replace the park pin. I had swapped the trans out a couple weeks before that and everything was working when I took it in.
Really don't want to have to put it in a shop if I don't have to since its my daily driver. Hoping its something I fix at the house. I'll check the power across the fuses and go from there.
Old 08-04-2013, 07:03 PM
CB56 CB56 is offline
Vehicle: 2000 Dodge Ram 2500
Trim Level: Laramie SLT
CB56 is on a distinguished road
Did you find the electrical problem? If you did, I sure would appreciate it if you would post it. I have the same problem. I will start trouble shooting in a day or two. I will post if and when I find something. CB
Old 03-11-2014, 10:10 PM
Another brick Another brick is offline
Vehicle: 1998 Dodge Ram 2500 Diesel 4x4
Trim Level: Used
Color: Green
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Another brick is on a distinguished road
Is there room in the boat for me, too?
Aggravating issue, at the least~
Old 03-15-2014, 10:41 AM
FilthyDog's Avatar
FilthyDog FilthyDog is online now
Vehicle: 1999 Dodge Ram 1500
Trim Level: SLT Laramie
FilthyDog is on a distinguished road
I just finally solved this problem on my truck. The final culprit was the overhead console. SO add that to the list of items to unplug while trouble shooting.
Mods: Hughes FI Intake, Stainless Steel Short Headers(generic ebay), Rebuilt Cylinder Heads, K&N Cold Air Intake, IAT Mod, Hughes STAGE 1 MODIFIED O.E.M. THROTTLE BODY, High Flow exhaust, LineX Bed Liner
